21593 Discussions
oscillatory circuit for LFXP6C-5TN144C
I'm developing a FPGA programmer using LFXP6C-5TN144C as core. I'm stuck with the designing of oscillatory circuit for the same. I'm stuck with the development of 24MHz circuit at 3.3v.
kindly inform me were could i get this type of crystal oscillator. I have checked onto many sites like fox electronics, electronics-manufacturers....etc.but haven't found the correct one.
i did goggled "crystal oscillator 24MHz" but got circuits generating this frequency. but the problem is that they generate this frequency with 5v, the think i need is of 3.3v...as my FPGA supports voltage range from 2.8v-3.3v
kindly post the reply as soon as possible, so that i can fasten my work.
pls, anyone who knows a solution for this problem kindly post ur views and suggestions....
thank you
varun v g
A crystal oscillator is the usual solution. 24 MHz 3.3V oscillator is a standard product, available in different packages, e.g. DIL, SMD.
--- Quote Start ---
--- Quote End ---
hello,
first of all thank you for your reply.
kindly inform me were could i get this crystal oscillator. I have checked onto many sites like fox electronics, electronics-manufacturers....etc.but haven't found the correct one.
thank you
varun v g
such a component is as common as a resistor, capacitor, connector, screws,...
digikey, farnell and uncounted others have them on stock.
there are so many manufatures out there ...
have you googled for "crystal oscillator 24MHz" ???
digikey (http://search.digikey.com/scripts/dksearch/dksus.dll) gives 183 results when looking for a 24MHz oscillator
thank u for ur assistance....
thanks and regards
varun v g
You obviously didn't look hard enough. The second Digikey hit is a 3V part. Lots of 3.3V parts are also available.
Jauch VX3F is a part that runs at 3,3V ...
realy there are at least a dozend manufature that can be second source to each other as replacement for the same footprint.
hello,
I'm heartly delivering thanks to all of you for helping me with your knowledge. I got an apt crystal oscillator much suitable for my application (a 4 pin SMD from CTS).
thank you all
thanks and regards
varun
