21588 Discussions
problem sdram controller read/write FIFOs. NEED HELP !
hello all
Please i need your help , i've been strugling with this problem for a while.
well i would like to display two images on a vga screen. and i'm using the sdram to temporarely save frames before display. when i was using only one image i didn't have any problem i had two write fifo and two read fifo. but when i attempt to write/read another image means i added two other FiFOs for the write and two other read Fifos for the read, i get a mess on the vga display, knowing that i added a display module to select to decide where to display the image since i divided the screen into 2. if (WR1_LOAD) rWR1_ADDR <= WR1_ADDR; else if (mWR_DONE&&WR_MASK) begin if (rWR1_ADDR<WR1_MAX_ADDR-WR1_LENGTH) rWR1_ADDR <= rWR1_ADDR+WR1_LENGTH; else rWR1_ADDR <= WR1_ADDR; end // Write Side 2 if (WR2_LOAD) rWR2_ADDR <= WR2_ADDR; else if (mWR_DONE&&WR_MASK) begin if (rWR2_ADDR<WR2_MAX_ADDR-WR2_LENGTH) rWR2_ADDR <= rWR2_ADDR+WR2_LENGTH; else rWR2_ADDR <= WR2_ADDR; end // Write Side 3 if (WR3_LOAD) rWR3_ADDR <= WR3_ADDR; else if (mWR_DONE&&WR_MASK) begin if (rWR3_ADDR<WR3_MAX_ADDR-WR3_LENGTH) rWR3_ADDR <= rWR3_ADDR+WR3_LENGTH; else rWR3_ADDR <= WR3_ADDR; end // Write Side 4 if (WR4_LOAD) rWR4_ADDR <= WR4_ADDR; else if (mWR_DONE&&WR_MASK) begin if (rWR4_ADDR<WR4_MAX_ADDR-WR4_LENGTH) rWR4_ADDR <= rWR4_ADDR+WR4_LENGTH; else rWR4_ADDR <= WR4_ADDR; end // Read Side 1 if (RD1_LOAD) rRD1_ADDR <= RD1_ADDR; else if (mRD_DONE&&RD_MASK) begin if (rRD1_ADDR<RD1_MAX_ADDR-RD1_LENGTH) rRD1_ADDR <= rRD1_ADDR+RD1_LENGTH; else rRD1_ADDR <= RD1_ADDR; end // Read Side 2 if (mRD_DONE&&RD_MASK) begin if (rRD2_ADDR<RD2_MAX_ADDR-RD2_LENGTH) rRD2_ADDR <= rRD2_ADDR+RD2_LENGTH; else rRD2_ADDR <= RD2_ADDR; end // Read Side 3 if (RD3_LOAD) rRD3_ADDR <= RD3_ADDR; else if (mRD_DONE&&RD_MASK) begin if (rRD3_ADDR<RD3_MAX_ADDR-RD3_LENGTH) rRD3_ADDR <= rRD3_ADDR+RD3_LENGTH; else rRD3_ADDR <= RD3_ADDR; end // Read Side 4 if (mRD_DONE&&RD_MASK) begin if (rRD4_ADDR<RD4_MAX_ADDR-RD4_LENGTH) rRD4_ADDR <= rRD4_ADDR+RD4_LENGTH; else rRD4_ADDR <= RD4_ADDR; end end
this is a part of the sdram controller
in the main program the sdram is mapped this way
Sdram_Control u7 ( // HOST Side .RESET_N(KEY), .CLK(sdram_ctrl_clk), // // FIFO Write Side 1 .WR1_DATA({1'b0,sCCD_G,sCCD_B}), .WR1(sCCD_DVAL), .WR1_ADDR(0), .WR1_MAX_ADDR(640*480/2), .WR1_LENGTH(8'h50), .WR1_LOAD(!DLY_RST_0), .WR1_CLK(PIXCLK), // // // FIFO Write Side 2 .WR2_DATA({1'b0,sCCD_G,sCCD_R}), .WR2(sCCD_DVAL), .WR2_ADDR(23'h25800), .WR2_MAX_ADDR(23'h25800+640*480/2), .WR2_LENGTH(8'h50), .WR2_LOAD(!DLY_RST_0), .WR2_CLK(PIXCLK), // // // FIFO Write Side 3 .WR3_DATA(data_test1), .WR3(valid), .WR3_ADDR(23'h60000), .WR3_MAX_ADDR(23'h85800), .WR3_LENGTH(8'h50), .WR3_LOAD(!DLY_RST_0), .WR3_CLK(PIXCLK), // // // FIFO Write Side 3 .WR4_DATA(data_test2), .WR4(valid), .WR4_ADDR(23'h90000), .WR4_MAX_ADDR(23'h90000+640*480/2), .WR4_LENGTH(8'h50), .WR4_LOAD(!DLY_RST_0), .WR4_CLK(PIXCLK), // FIFO Read Side 1 .RD1_DATA(Read_DATA1), .RD1(vga_read), .RD1_ADDR(0), .RD1_MAX_ADDR(640*480/2), .RD1_LENGTH(8'h50), .RD1_LOAD(!DLY_RST_0), .RD1_CLK(~VGA_CTRL_CLK), // // // FIFO Read Side 2 .RD2_DATA(Read_DATA2), .RD2(vga_read), .RD2_ADDR(23'h25800), .RD2_MAX_ADDR(23'h25800+640*480/2), .RD2_LENGTH(8'h50), .RD2_LOAD(!DLY_RST_0), .RD2_CLK(~VGA_CTRL_CLK), //// ////// // FIFO Read Side 1 .RD3_DATA(Read_DATA3), .RD3(vga_read), .RD3_ADDR(23'h60000), .RD3_MAX_ADDR(23'h85800), .RD3_LENGTH(8'h50), .RD3_LOAD(!DLY_RST_0), .RD3_CLK(~VGA_CTRL_CLK), //// // // FIFO Read Side 2 .RD4_DATA(Read_DATA4), .RD4(vga_read), .RD4_ADDR(23'h90000), .RD4_MAX_ADDR(23'h90000+640*480/2), .RD4_LENGTH(8'h50), .RD4_LOAD(!DLY_RST_0), .RD4_CLK(~VGA_CTRL_CLK), // SDRAM Side .SA(DRAM_ADDR), .BA(DRAM_BA), .CS_N(DRAM_CS_N), .CKE(DRAM_CKE), .RAS_N(DRAM_RAS_N), .CAS_N(DRAM_CAS_N), .WE_N(DRAM_WE_N), .DQ(DRAM_DQ), .DQM(DRAM_DQM) );
Please need any help . i stuck with this . thank you so much
i've a DE2-115 Board and i'm using quartus 10.0
please any help
pleaaaaaaaaaaaaaaaaaase i`m desperately looking for any help !!!
