Hi;
I try write a code for convert integer to ufixed: package my_data_types is type vector is array (natural range <>) of integer; type ufixed is array (natural range <>) of std_logic; end my_data_types; library ieee; library ieee_proposed; use ieee_proposed.fixed_pkg.all; use work.my_data_types.all; entity fix is port (clk: in bit; nprev: in vector (0 to 7); ip1: out ufixed (3 downto -4)); end fix; architecture fix of fix is signal n1: ufixed (3 downto -4); begin process(clk) begin if (clk'event and clk='1') then for i in 0 to 7 loop ip1(i) <= to_ufixed (nprev(i),n1); end loop; end if; end process; end fix; I get this error: Error (10482): VHDL error at fix.vhd(3): object "std_logic" is used but not declared. How to declare the "std_logic" in package?..Link Copied
First of all. DO NOT declare your own version of ufixed, it is in the fixed_pkg library. You are going to have problems if you do this.
Secondly, you need to include the line: library ieee; use ieee.std_logic_1164.all;- Mark as New
What the right way to declare ufixed as an array?..thanks for reply
you dont need this
type ufixed is array (natural range <>) of std_logic; It is already declared in the fixed_pkg.- Mark as New
Now I get this error:
Error (10511): VHDL Qualified Expression error at fix.vhd(23): to_ufixed type specified in Qualified Expression must match std_ulogic type that is implied for expression by context. At this line: ip1(i) <= to_ufixed (nprev(i),n1); Why?..thanks for reply- Mark as New
ip1(i) is a single bit. You cannot assign an entire array (the ufixed) to a single bit.
You need to decalre an array of ufixed values.- Mark as New
Sorry Tricky, I don't get what you say. How to declare an array of ufixed values? Thanks for reply
type ufixed_array_t is array(natural range <>) of ufixed(3 downto -4);
signal a : ufixed_array_t(0 to 7); etc- Mark as New
This is my package code:
package my_data_types is type vector is array (natural range <>) of integer; type ufixed_array_t is array (natural range <>) of ufixed (3 downto -4); end my_data_types; But then, error said: Error (10482): VHDL error at fix.vhd(3): object "ufixed" is used but not declared How to avoid this error?..Thanks for reply- Mark as New
you need to include the fixed_pkg.
I already include the fixed_pkg..
you clearly didnt for the package. you have to have separate library imports for each package and entity
What do you mean by "separate library imports for each package and entity"?
in your code, you have the package above the library includes.
you need to do this:
--libraries for the package
library ieee;
library IEEE_Porposed;
use IEEE_Proposed.fixed_pkg.all;
package my_package is
end package;
--Now the libraries for the entity
library ieee;
use work.my_package.all;
Usually, you would put the package and entity in a separate file.
Thanks Tricky..I learn a lot from you. I appreciate it.
May I suggest you read a VHDL tutorial - a lot of the questions you are asking are very very basic.
Yes, I will. Since now, I still learn form vhdl tutorial and other materials for my better understand.Thanks for the advise =)
