Hello,I am a green hand of FPGA field.And right now I am designing a FPGA PCIe--IoBUs bridge using EP4CGX15.
In the IP doc,It is said:"To improve PCI Express throughput, Altera recommends using an Avalon-MM burst master without any byte-enable restrictions." What does it mean? To disable the byte enable?Or I should use a Avalon-MM master which the MASTER doesn't have byte-enable restirctions? Best Regards~ Young SuitJuneLink Copied
