21600 Discussions
"ofs_plat_if" Directory missing in the OPAE root directory
AdityaJain
I'm trying to compile my System using OPAE, it uses "ofs_plat_afu" top-interface which requires "ofs_plat_if" directory in the OPAE root folder.
But, after using the "tools_setup" command to set the $OPAE_PLATFORM_ROOT variable, the set path does not have the "ofs_plat_if"  directory.
How can I get this directory?
AnilErinch_A_Intel
Hi ,
Please find the ofs_plat_if directoy in the path below
https://github.com/OPAE/ofs-platform-afu-bbb/tree/master/plat_if_develop
Please edit the environment variables accordingly if path needs to be added.
Thanks and Regards
Anil
