21616 Discussions
r-tile pipe direct emib deskew
shivajim
Hello Intel,
The r-tile user guide for pipe direct mode says on deskew that user application logic should toggle txdeskewmarker_i, but it looks not clear. Can someone tell me when this signal toggle after reset / afterr-tile start generating the *_tx_clk_out_o ? what data to be sent on *_txdata?
Every 16 cycles - means 1 pulse cycle where some data is to be transferred on *_txdata and wait for *_dsk_valid_0, if not then second pulse should be sent and so on, what should be done?
Is this not required for rx?
Labels (2)
RongYuan
We sincerely apologize for the inconvenience caused by the delay in addressing your Forum queries. Due to an unexpected back-end issue in our system, your Forum case, did not reach us as intended. As a result, we have a backlog of cases that we are currently working through.
I think you can simply trigger the deskew marker every 16 clock cycles. No worry about txdata stuff.
Rong
RongYuan
This case is set to close.
Rong
