21615 Discussions
read write from an aonchip memory!!!!
hello,
i m a beginner, i try use an onchip memory. i can't perform read and write operation with onchip memory.
i can't found an C example that help me access to the memory.
i have writen c code:
# include "io.h"# include "system.h"# include <stdio.h># include "Data.h"# include "sys/alt_irq.h"
int i;
int h;
int *z;
int Acc0k;
long cpt_AlleleAccMaster;
int cpt_Allele;
int cpt_iteration;
int Nb_Nucleotides;
int *z1;
int *k;
void InitDNA()
Acc0k = 0;
cpt_Allele = 0;
cpt_AlleleAccMaster = 0;
cpt_iteration = 0;
Nb_Nucleotides = 64;
z1 = (unsigned int*)0x02100000;
for (i=0;i<Nb_Nucleotides;i=i+4)
h = (G[i]);
*z1 = h;
z1 = z1 + 1;
int main()
InitDNA(); //read (load) data from data.h
k= (unsigned int*)0x02100000;
for(i=0;i<16;i++)
printf("%x\t",*(k+i));// display data
can someone help me ?
thk for all members
doe's 0x02100000 address correspond to a on chip memory cell? did you check it at sopc builder?
in that case you should declare you pointer as volatile
# define ON_CHIP (*(volatile unsigned int *)0x02100000)
thnk you parrado, i success running my program with an onchip memory.
best regards
