reg usb blster
hi
i am using usb blaster with 64 bit vista OS. but it is not working. i am not able to install driver..it will support 64 bit OS or not? but in usb blaster user manual 64 bit vista also mentioned .
with regards
--- Quote Start ---
hi
with regards
--- Quote End ---
Drivers starting from Quartus 9.1 are supporting the 64b-versions of Vista and Win7.
If you do not want to install Q9.1 for some reason, you can use our eeblaster (http://www.entner-electronics.com/tl/index.php/eeblaster.html)(which is an improved and less expensive USB-Blaster-clone) with our driver (please indicate this special situation when ordering, normally EEBlaster also uses the Quartus-driver).
Thomas
