21615 Discussions
remote update issue
about the remote system update for the cyclone iii devices,i have checked many archives,but,so far , i don't understand what shouid i do.
how many steps to accomplish the update?
what is the factory image?
The documents needed are:
http://www.altera.com/literature/hb/nios2/qts_qii55017.pdf
http://www.altera.com/literature/hb/cyc3/cyc3_ciii51016.pdf
http://www.altera.com/literature/an/an521.pdf
Basically the FPGA will always boot a "factory" image first. It is up to this "factory" image to configure the remote update core to attempt to boot another image known as the "application" image. The remote update core has sufficient circuitry to detect if a failure occurs while attempting to run the "application" image; in which case the "factory" image will be rebooted.
So your "factory" image needs to have enough brains to know why it booted and whether or not to try to load an "application" image. It can detect what caused the boot by reading status bits in the remote update core.
While running the "application" image, you can boot back to the "factory" image (which you might do if you've remotely updated the "application" image and want to restart).
Jake
Thanks a lot!
But i still have some questions as follows:
1.If using the ALT_ASMI core to control the EPCS device(like EPCS4), so ,the factory image how to communicate with the ALT_ASMI core ?
2.What is the relationship between the factory image and the application image?
3.For the factory image, how to command the ALT_ASMI core to download the application image?
PS:In my design,i use the user logic to control the whole procedure. But i don't know clear about the relationship between the remote update core and the factory image,application image.
