21616 Discussions
replacement for --> EP1C6Q240C8N, EP1C20F400C7, EP1C3T100C7. Altera component end of life
spete4
I work with components -->
 1. EP1C6Q240C8N
 2. EP1C20F400C7
 3. EP1C3T100C7
those components are END OF LIFE, I wanted to receive proposals for parallel components that would be FFF, at the level of DROP,
ShafiqY_Intel
I’m not quite understand when you said “…I wanted to receive proposals for parallel components that would be FFF, at the level of DROP”. Can you explain a little bit more what you mean by that?
Since you are using Cyclone device in your design, maybe you can try our latest Cyclone device (Cyclone V or Cyclone 10). These device have latest technology and features compare to previous device.
Please refer to Intel website for more details.
https://www.intel.com/content/www/us/en/products/programmable.html
Thank you.😉
spete4
FFF = Form Fit Function: Ensure that part changes have a minimal impact on your manufacturing process
We need a direct replacement for the original component that don't require a change to the PCBA (the same pin layout   ) and supports the same original code
ShafiqY_Intel
I’m apologize to say that there is no direct replacement for Cyclone FPGA Device (this device was introduced in 2002).
I’m sorry for any inconvenience may caused you.
Thank you.
