21611 Discussions
run ONEAPI devcloud FPGA Hardware issues
Wei-Chih
Hello Intel ONEAPI devcloud
I meet some issues when i run my code on devcloud jupyter using fpga hardware. (follow this website tutorial:  https://devcloud.intel.com/oneapi/documentation/base-toolkit/)
I can run my code by using GPU and FPGA emulator but when I tried to run FPGA hardware node it will get errors as below:
for arria10 error :
terminate called after throwing an instance of 'cl::sycl::runtime_error'
what(): Native API failed. Native API returns: -42 (CL_INVALID_BINARY) -42 (CL_INVALID_BINARY)
make: *** [run_fpga_hardware] Aborted
for stratix10 error:
terminate called after throwing an instance of 'cl::sycl::nd_range_error'
what(): Non-uniform work-groups are not supported by the target device -54 (CL_INVALID_WORK_GROUP_SIZE)
make: *** [run_hw] Aborted
Do you know what are the problems and  how can I modify my code?
thanks
KennyTan_Altera
Thanks for using Intel community forum,
Kindly expect some delay in the reply due to holiday.
aikeu
Hi Wei-Chih,
May I know are you modifying your code using the VectorAdd sample project?
Can the VectorAdd sample project run on properly on your side?
Aik Eu
Wei-Chih
Hi Aik
 I did the vector add before, all devices can run, but it  seems  stratix10 have connection problem now.
aikeu
Hi Wei-Chih,
Are you able to access the other nodes for Stratix10?
Nodes with Stratix 10: (2 available/5 total)
s005-n005 s005-n008
Nodes with Stratix 10 OneAPI: (3 available/3 total)
s001-n142 s001-n143 s001-n144
Aik Eu
Wei-Chih
Hi Aik
I have tried s001-n142 s001-n143 s001-n144, but stratix10 nodes are still having the error
aikeu
Hi Wei-Chih,
May I know is it a connection problem or it is a code running problem?
Any return logs to show?
Aik Eu
Wei-Chih
Hi Aik
I think it's not code running problem cause I can use Arria10 normally. Below is error message.
aikeu
Hi Wei-Chih,
I see there is a hardware error for Stratix10 also after I tried with it using Jupyter Lab and Mobaxterm access. Seems like the vector add project is not working on Stratix10 but only Arria10 was working fine. I will submit a ticket regarding this matter and it will take time to resolve this.
May I know if there is any concern on your side regarding this?
Aik Eu
Wei-Chih
Hi Aik
Thanks. I will use Arria10 to test my own project currently, if you fix Stratix10 issue please inform me cause I intent to compare different fpga hardwares on my project.
aikeu
Hi Wei-Chih,
Sure, will inform you through email once the Stratix10 hardware running issue resolved.
I will close this thread for now.
Aik Eu
