21608 Discussions
serial to parallel
hi all
here is my problem...
i would like to connect range sensor to DE2 kit to show results of the range..
i tried the analog output of the EZ0 maxsonar sensor ...there is one analog input in this DE2 called" MIC in" and i don't Know how to play with.
and tried the pulse width output by a VHDL code using counters and there is no result,,,
still the TX output....
the TX output delivers asynchronous serial with an RS232 format, except voltages are 0-Vcc. The output is an ASCII capital “R”, followed by three ASCII character digits representing the range in inches up to a maximum of
255, followed by a carriage return (ASCII 13). The baud rate is
9600, 8 bits, no parity, with one stop bit
9600 baud rate means each bit needs 1/9600 sec ,,,,,means f=9600 HZ....
How can i do this..?
DE2 gives 50,27 Mhz clk!
is there any "megafunctins" helps me with this?
should i use memories,,? or serial to parallel converters ? or buffers?
really i don't know from where i have to start
ok....i found somthing helpful
here is my new qeustion...
how can i build UART using DE2?
