Hi all;
I have learn about ufixed and sfixed operation. I want to convert -0.129 to sfixed using the code below and its has no problem; signal n1: ufixed (4 downto -4); ... out_A <= to_sfixed(-0.129,n1); Then, I want to convert this out_A(sfixed value) to ufixed..How can I do like that? Need helps..thanksLink Copied
you cant really do that, because ufixed is unsigned fixed, and sfixed is signed fixed.
Therefore, using a ufixed to size an sfixed is not appropriate. and direct conversion from sfixed to ufixed would be innapropriate without an abs function. so, dont put signed numbers into ufixed. Keep them sfixed.- Mark as New
Sorry for the miss typing; signal n1: sfixed (4 downto -4);
How can I convert the sfixed to ufixed using abs function? Can you give any links or note on abs function to study..thanks for reply- Mark as New
I write the code below and its work;
------------------------------------------------------------- Library ieee; USE ieee.std_logic_1164.all; use ieee.numeric_std.all; library ieee_proposed; use ieee_proposed.fixed_pkg.all; ENTITY try IS PORT( y : IN sfixed(4 downto -4); Clock : IN STD_LOGIC; alphaEstOut : OUT ufixed(5 downto -4)); END try; ARCHITECTURE Behavior OF try IS SIGNAL aa : sfixed(y'high +1 downto y'low); BEGIN PROCESS(Clock) BEGIN IF rising_edge(Clock) THEN aa<=abs(y); alphaEstOut<=ufixed(aa); END IF; END PROCESS; END Behavior;- Mark as New
Now, I proceed to next stage which is multiply the conversion output with ufixed values (input).
library ieee; library ieee_proposed; use ieee_proposed.fixed_pkg.all; package my_data_types is type vector is array (natural range <>) of integer; type ufixed_array_t is array (0 to 3) of ufixed (9 downto -10); end my_data_types; library ieee; library ieee_proposed; use ieee_proposed.fixed_pkg.all; use work.my_data_types.all; entity mul_four is port (clk: in bit; A: in vector (0 to 3); out_A: out ufixed_array_t); end mul_four; architecture mul_four of mul_four is signal n1: sfixed (4 downto -4); signal n2: sfixed (n1'high + 1 downto n1'low); signal n3: ufixed (5 downto -4); signal u: ufixed (5 downto -4); begin process(clk) begin if (clk'event and clk='1') then n1 <= to_sfixed(-0.129,n1); n2 <= abs(n1); n3 <= ufixed(n2); end if; for i in 0 to 3 loop out_A(i) <= (to_ufixed (A(i),u)) * n3; end loop; end process; end mul_four; There are no error when I compile in quartus, but then an error occur in ModelSim:# Cannot continue because of fatal error. ( at line 36). Can anyone check my code?..do I write in wrong way?..need helps- Mark as New
you've got the sizing wrong.
(5 downto -4) * (5 downto -4) would give you a (11 downto -8) result. out_A(i) is (9 downto -10), so it doesnt fit properly. BUT there are the correct number of bits, so you effectivly just divided the result by 4. Secondly - you cannot put the loop outside of the clock branch. Move the for loop into the clocked bit of the process.- Mark as New
Oh, I not realise the size of the array is wrong. Thanks for remind me..
This is the architecture code:
... architecture mul_four of mul_four is signal n1: sfixed (4 downto -4); signal n2: sfixed (n1'high + 1 downto n1'low); signal n3: ufixed (5 downto -4); signal u: ufixed (5 downto -4); begin n1 <= to_sfixed(-0.129,n1); n2 <= abs(n1); n3 <= ufixed(n2); process(clk) begin if (clk'event and clk='1') then for i in 0 to 3 loop out_A(i) <= (to_ufixed (A(i),u)) * n3; end loop; end if; end process; end mul_four; I have simulate in ModelSim and the output seem like correct. I just want to confirm,do I convert the sfixed to ufixed in the right way?..thanks for helps
