21604 Diskussionen
small boot copier for EPCS
Geehrter Beitragender II
3.962Aufrufe
I have a customized board, with 5CEBA4 and EPCS16. I want the FPGA boot from a specified SW image address after the HW image is loaded.
I studied AN458, and I think the small boot copier is good for my application. But the source code of AN458 is for cfi flash, not EPCS. Besides, I don't need the image header, and the .flash format is too large for EPCS16. Anyone else experience something similar? Please give me some help!
Besides, I find someone has directly modified the bootloader software as: http://www.alteraforum.com/forum/showthread.php?t=28813. If it works, anyone could show me which files are needed, how to modify the boot address, and how to compile them with Nios2 SBT?
Thank you very much.
Derek
15 Antworten
1.474Aufrufe
AFAIK AN458 applies both to cfi flash and epcs.
Moreover the AN comes with a design example including bootloader source code and makefile to compile it.
1.474Aufrufe
Hi Cris72,
Thank you very much for you reply. I guess I miss-understand the source code of small_boot_copier.s.
Besides, I think if I don't have the header in the image file, I can skip the header check by comment the following code directly:
// Check the boot image signature
nextpc return_address_less_4
br read_32b_from_flash
mov temp_data, return_value
movhi expected_value, %hi(VALID_BOOT_SIGNATURE)
ori expected_value, expected_value, %lo(VALID_BOOT_SIGNATURE)
bne temp_data, expected_value, error
// Now we can begin copying the boot record to RAM. This loop
// reads each individual record in the boot record, and copies it
// to the appropriate location in RAM. If the record is a JUMP
// record, the loop breaks and branches to the address indicated
// in the JUMP record.
// Increment flash_ptr by 28 to skip past the boot image header and into
// the real boot record (we already incremented it by 4 when we read the
// signature)
// You may wish to do more with the header information than just skip
// past it. If so, this is the place to do that.
addi flash_ptr, flash_ptr, 28
Am I right?
Thanks again.
Derek
1.474Aufrufe
If indeed your application image does have a header I don't think it would be a good idea to skip the signature check.
You may need to change the VALID_BOOT_SIGNATURE parameter and recompile.
If the header block has not been included in the image, I guess it's ok commenting out the code you quoted.
In any case you must update FLASH_BASE and BOOT_IMAGE_OFFSET parameters according to your design,
otherwise the image won't load.
1.474Aufrufe
Hi Cris,
When I try to make the small_boot_copier, it always halt after echo "compiling to obj / small_boot_copier.elf". And after I key in "Ctrl+C", the programmer goes on, but this hex file doesn't work.
I am using Quartus 13.1 with NIOS2 command shell [gcc4]. The command elf2flash can work only when I start the shell from Qsys->tool. But this shell also halts when I make the small_boot_copier.
I am puzzled with this issue. Could you please give me some suggestion?
Derek
http://www.alteraforum.com/forum/attachment.php?attachmentid=9794&stc=1
1.474Aufrufe
What's your OS?
If you are using Win8 probably this thread can help you:
http://www.alteraforum.com/forum/showthread.php?t=43526
I also noticed that you installed Quartus on disk D. Could be this the reason the shell commands don't work in some cases?
1.474Aufrufe
Hi Cris,
Thank you very much for your quickly reply.
I still doubt whether the small_boot_copier.s can be used for EPCS. Because at the head of this file defines:# define BOOT_IMAGE_ADDR ( FLASH_BASE + BOOT_IMAGE_OFFSET )
I guess this code can't work for EPCS, am I right? If so, do you have some example how to generate the small_boot_copier for EPCS?
I also tried to use the advanced boot copier. But I am using Quartus 13.1 in windows 7 (64), and I can generate the elf file only with the Nios2 SBT. I am not familiar with the linux style and don't know how to merge the example to my own hardware. Could you please help me?
Thanks again,
Derek
1.474Aufrufe
I don't use this boot loader, but I'm almost sure it works for epcs, too.
FLASH_BASE is the base address of the EPCS (or any cfi flash) as defined in Qsys.
BOOT_IMAGE_OFFSET is the position of the Nios firmware in the image you store in epcs.
You should have the fpga hw image at epcs address 0. The image size is usually fixed for a specific fpga device; let's say size=0x174500.
Then you can conveniently place the Nios sw at address 0x180000 and this is the value you must pass into the BOOT_IMAGE_OFFSET parameter.
Upon board reset, the fpga will load from epcs address 0. Then the boot copier will instruct Nios to load the firmware starting from epcs address 0x180000.
Please pay attention to these requirements, otherwise you could not boot from epcs, even if you succeed in compiling the boot loader:
- in Quartus settings, epcs pins must be configured to be used as general purpose I/O, otherwise Nios can't use them to access epcs
- the generated hex file of the boot copier must be associated to the epcs component, i.e. in Qsys you must refer to it as epcs memory initialization file
- after you compile the boot copier code, you must rebuild the Quartus project (actually you only need to rebuild the memoy initialization files)
1.474Aufrufe
Hi Cris,
I think I have maken some progress. I forget to associate the hex file to the boot_rom in the Qsys, because the AN458 doesn't tell me to do it. I also managed to compile the small_boot_copier.s with Quartus 11.0.
Now, the performance of my board is. The hw boot normally, then the sw image is copied. Then the hw lost. I checked the binary file of the my sw, and I found the destination address(2nd 4 bytes) is set to 0x1000, which is the cpu address.
I have checked the bin file of the sw before, the destination address is set to 0x200020.
My nios address is:
cpu 0x1000
sram 0x200000
boot_rom 0x1c00
epcs 0x0
I also set the reset_vector to 0x1c00, and exception vector to 0x200020.
In Nios2 SBT, the bsp editor showes all the linker section are pointing to sram, except .entry to boot_rom.
Do you know where to set this destination address?
Thank you very much. Please forgive me for my bad english.
Derek
1.474Aufrufe
What do you mean with cpu address? The cpu is a bus master, then it doesn't have an address!
Do you mean the address of the jtag debug module?
reset_vector and exception_vector are ok. Anyway I wonder why you are using an additional boot rom: epcs device already includes onchip ram to store the boot code.
So you'd better place here your boot copier hex and set reset_vector to epcs base address.
1.474Aufrufe
Yes, the 0x1000 is the jtag address.
Could you please tell me how to put my hex file into the ocram inside epcs?
Derek
1.474Aufrufe
I can't access Quartus right now in order to check, but if I remember correctly, you simply need to point to the right bootloader hex in the epcs device properties in Qsys/SOPC builder.
Then, again in Qsys, in Nios properties, you set epcs base address as nios reset vector
1.474Aufrufe
Hi Cris,
I am using "EPCS/EPCQx1 serial flash controller" IP, but I can't find the entry to set the .hex file. Could you please help me to double check it when you are available?
Thank you and best wishes,
Derek
1.474Aufrufe
You are right. I forgot this point.
Actually the epcs mif points to a epcs_controller_boot_rom.hex file which is automatically added by Quartus to your project folder whenever you instantiate the epcs component.
If you want to use a custom boot loader, you must rename your hex this way and replace the default one.
The tricky part is that the regular file is copied again from Quartus library each time you regenerate the system with Qsys; then you must remember to replace it again with the custom one whenever you make any change in Qsys, otherwise fpga would configure epcs with the standard boot loader and your nios application won't start.
I never bothered if there's a better way to do this, although I think so.
1.474Aufrufe
Hi Cris,
I am happy to report I get it done finally. I choose another example, http://www.alterawiki.com/wiki/epcs_bootloaders, follow its instruction, and it works.
Thank you very much for your sharing.
Best wishes,
Derek
1.474Aufrufe
Hi Cris,
I am happy to report that I get it done. I follow another example http://www.alterawiki.com/wiki/epcs_bootloaders, and it works.
Thank you very much for your sharing,
Derek
Antworten
