Programmable Devices
21616 Discussions
sorting time issue
I want to calculate the time taken to sort the files alphabetically. I am using timestamp driver. In the output gives me the sorted file names but the the time taken to sort it is always zero.
I am using DE2 board. Following is my code
#include "sys/alt_timestamp.h"# include "alt_types.h"# include <stdio.h># include <string.h> //Sort() definition int main() { int i; /* loop variable */ alt_u32 time1; alt_u32 time2; alt_timestamp_start(); time1 = alt_timestamp(); //sort(); time2 = alt_timestamp(); printf("Time taken to print = %u ticks\n", (unsigned int)time2-time1); printf("Number of ticks per second = %u\n",(unsigned int)alt_timestamp_freq()); }
Here are some points that I would check first :
- Are you sure you have a timestamp component in your system ?
- Check the value returned by alt_timestamps_start() (0 if success)
- Which value return alt_timestamps_frequency() ?
- the // before your sort function is just here, it is not really in your code (just to be sure) ?
Jérôme
Thanks for the reply.
The problem was I have sys_clk_timer enabled in my system. I turned it off and now it is working fine. :)
