21615 Discussions
specifications of external clock signal DE2 Board and Starter Development Board
Hi, im trying to synchronize a comunication system with a 10MHz clock, for that, I'm using a PLL IC (MM74HC4046), then the main issue is that this IC gives 5 Volts signal, and after research of my boards, I've seen that they have some diodes to protect the GPIO, but not the external clock signal wich is the one that I have to use because I want to use the PLL of the FPGA to compensate the phase that my IC gives me.
How ever, I dont have found any information about the specifications of the signal acepted by the board, so I could make an arrange.
Would be good to know the specification of the clock signal and/or IC to match this for any board (DE2 [EP2C35F672C6] or Started Development [EP2C20F484C7N] )
Look at the schematic for the DE2. I just looked at an old printed copy and the external clock SMA connector is followed by a 1k pull-down and then goes directly to an FPGA pin.
If you have the clock source close to the board, then you could put a 1k series resistor between the clock source and the DE2 board. That external 1k and the on-board 1k would create a voltage divider, resulting in a clock signal with a peak of about 2.5V on the FPGA pin - this assumes that you do not have much ringing though - so check with an oscilloscope. If you look in the handbook you will find there is a specification for ringing/overshoot. So long as you're under the handbook values, you will not damage the FPGA clock input pin.
Cheers,
Dave
I've seen the datasheet of the FPGA, and it says that voltage accepted by the pins depends on the duty cycle of the signal (DC 4.0V, 10% duty Cycle 4.5V).
I dont see the minimun voltaje level for a HIGH, but If it dont work I'll just decrease the serial resistor to get more than 2.5V
Thanks for the advice
