21618 Discussions
speeding up a software program originally wriiten in c
i am newbie to fpgas programming. I have been programming in c and Fortran for many years.
I want to speed up a c program hopefully, by 100x. I have already speeded it up by
8x by using a multicore CPU and GPU programming. I want it to go faster.
Is there a book or whitepaer somewhere on this site or the internet taht walks one through an example?
I also think that to convert a c program of some complexity, one must initially create a dataflow
diagram and then work with that. This is take advantage of an fpgas maximum parallellism and
pipelining capability.
Is there software that will help a program to create a dataflow diagram from c source?
Any assitence appreciated.
Thanks in advance.
Resepcfully,
Lou_Reed
Create a dataflow diagram from c source with a tool : good luck !
You can "speed up" a c program by many ways :
- redesign the project from draft to produce a digital schema (And , or, not, D flip flop) Finite state machine which FPGAs are intended for.
- convert some functions in VHDL (Altera call them "accelerated C functions") which can partially speed up the borad.
It highly depends of your project.
