21602 Discussions
sram read and write
i am trying to alter the data stored(by control panel) in sram .i wrote the vhdl program to alter the data and i am reading with control panel to see if it is changed...my problem is every time i am reading only "1" on the data pins...i learnt that before reading the datawe need to put the biderectional data pins in high impedance state.i tried that also...my program is
LIBRARY ieee ;
USE ieee.std_logic_1164.all ;
use IEEE.std_logic_unsigned.all;
entity abc is
port(clk:in std_logic; --Input from FPGA switches
din:inout std_logic_vector(15 downto 0); -- Data outputs/inputs from/to SRAM from/to FPGA
ceo,oeo,weo,lbo,ubo:out std_logic; --Inputs to SRAM from FPGA
addr:out std_logic_vector(17 downto 0)-- Address inputs to SRAM from FPGA
end;
architecture abcd of abc is
begin
ceo <= '0';
oeo <= '0';
lbo <= '0';
ubo <= '0';
process(clk)
variable temp_addr:std_logic_vector(17 downto 0) :="000010101011001010" ;
variable temporary: std_logic_vector(15 downto 0);
variable count,flg:integer range 0 to 100:=0;
begin
if clk'event and clk = '1' then
if (count<=10) then
if flg = 0 then
flg:= 1;
end if;
if flg = 1 then
din <= (others => 'Z');
addr <= temp_addr;
weo <= '1';
temporary := din;
flg := 2;
end if;
if flg = 2 then
temp_addr:=temp_addr+1;
weo<='0';
din <= temporary and x"10ff" ;
flg := 0;
count := count+1;
end if;
end if;
end if;
end process;
end;
can anybody please help me find the problem
It could be a good idea to observe the signals on the SRAM chip with signaltap to see if everything is working as expected.
Did you check if the pins were mapped correctly?
I think you need to deassert output enable (oeo?) in order to write.
i tried that also,but no use...:(..(oeo is the output enable pin )..all the pins were connected properly,the data is perfectly writen but reading is the problem...it is always reading '1's..
can you please post any basic program to read and write the sram...i'll try to infer something from that...i tried searching all over the net ,but i couldn't find it..thanks
in vhdl..........
I think the problem is you are assigning temporary when din is not 'Z'. when temporary is assigned, din is probably '0'.
i am actually new to this vhdl.....but please bear with me...as per i know we should apply 'z' before reading,and reading starts when i assign weo <='1'.so thats why i assigned first 'z' and then i placed address on ADDR port,and i gave weo <='1'...is'nt that the right order..how are you suggesting to do ?
hello...............
well helloooooooooooooooo triky
