21611 Discussions
testbench integer type
Dear all,
Below is my testbench code that i simulate in ModelSim.
library IEEE;
use IEEE.Std_logic_1164.all;
use IEEE.Numeric_Std.all;
entity reg_tb is
end;
architecture bench of reg_tb is
component reg
PORT (
input : IN integer RANGE -127 TO 127;
clk : IN bit;
output : OUT integer RANGE -127 TO 127
end component;
signal input: integer RANGE -127 TO 127;
signal clk: bit;
signal output: integer RANGE -127 TO 127 ;
constant clock_period: time := 10 ns;
signal stop_the_clock: boolean;
begin
uut: reg port map ( input => input,
clk => clk,
output => output );
stimulus: process
begin
-- Put initialisation code here
input <= "3";
clk <= "0";
wait for 100ns;
input <= "12";
clk <= "1";
wait for 100ns;
stop_the_clock <= true;
wait;
end process;
clocking: process
begin
while not stop_the_clock loop
clk <= '0', '1' after clock_period / 2;
wait for clock_period;
end loop;
wait;
end process;
end;
This is the error:
Error (10515): VHDL type mismatch error at reg_tb.vhd(35): integer type does not match string literal
Can anyone tell me, where I'm wrong..Many thanks
I replace the integer value from "3" to 3 and "12" to 12 and its okay.
But, know i has another error:
Error (10533): VHDL Wait Statement error at reg_tb.vhd(37): Wait Statement must contain condition clause with UNTIL keyword
Most of the testbench code that I has study uses Wait statement without UNTIL keyword..I'm confuse know..Anyone help me please.
Many thanks
You should have a space between 100 and ns but that should just issue a warning, not an error.
Are you sure this file is marked as a testbench and isn't run through the synthesizer?
I agree with Daixiwen - it sounds like you're trying to synthesize the testbench.
Dear Daixiwen,
I already fix the error. I run simulate the testbench code in ModelSim and its okay.
I has one question, how to make a testbench when we have several subcode.
For example, I has four vhd file:
(1)reg.vhd (2)adddiv.vhd (3)difference.vhd (4)haar.vhd
where haar.vhd is the main file of the program.
I want to make testbench for the main file.
Many thanks
instantiate Haar in your testbench. Make sure all files are compiled into the work library, and away you go.
Dear Tricky,
I has instantiate the haar.vhd file and also compile all others file in to library.
But, when I run it, the input is correct but no output is obtained. I don't know why. Below is my haar testbench code:
library IEEE;
entity haar_tb is
end;
architecture bench of haar_tb is
-------------Component Declarations---------------
component haar
PORT (
clock : IN bit;
in1 : IN integer RANGE -127 TO 127;
in2 : IN integer RANGE -127 TO 127;
in3 : IN integer RANGE -127 TO 127;
in4 : IN integer RANGE -127 TO 127;
in5 : IN integer RANGE -127 TO 127;
in6 : IN integer RANGE -127 TO 127;
in7 : IN integer RANGE -127 TO 127;
in8 : IN integer RANGE -127 TO 127;
out1 : OUT integer RANGE -127 TO 127;
out2 : OUT integer RANGE -127 TO 127;
out3 : OUT integer RANGE -127 TO 127;
out4 : OUT integer RANGE -127 TO 127;
out5 : OUT integer RANGE -127 TO 127;
out6 : OUT integer RANGE -127 TO 127;
out7 : OUT integer RANGE -127 TO 127;
out8 : OUT integer RANGE -127 TO 127
end component;
--------------Signal Declarations-----------------
signal clock: bit;
signal in1: integer RANGE -127 TO 127;
signal in2: integer RANGE -127 TO 127;
signal in3: integer RANGE -127 TO 127;
signal in4: integer RANGE -127 TO 127;
signal in5: integer RANGE -127 TO 127;
signal in6: integer RANGE -127 TO 127;
signal in7: integer RANGE -127 TO 127;
signal in8: integer RANGE -127 TO 127;
signal out1: integer RANGE -127 TO 127;
signal out2: integer RANGE -127 TO 127;
signal out3: integer RANGE -127 TO 127;
signal out4: integer RANGE -127 TO 127;
signal out5: integer RANGE -127 TO 127;
signal out6: integer RANGE -127 TO 127;
signal out7: integer RANGE -127 TO 127;
signal out8: integer RANGE -127 TO 127 ;
begin
---------------Component Instantiation--------------
uut: haar
port map ( clock => clock,
in1 => in1,
in2 => in2,
in3 => in3,
in4 => in4,
in5 => in5,
in6 => in6,
in7 => in7,
in8 => in8,
out1 => out1,
out2 => out2,
out3 => out3,
out4 => out4,
out5 => out5,
out6 => out6,
out7 => out7,
out8 => out8 );
stimulus: process
begin
---------------------First Test------------------
in1 <= 18;
in2 <= 5;
in3 <= 1;
in4 <= 9;
in5 <= 13;
in6 <= 6;
in7 <= 2;
in8 <= 3;
wait for 50ns;
---------------------Second Test------------------
in1 <= 10;
in2 <= 2;
in3 <= 3;
in4 <= 4;
in5 <= 15;
in6 <= 7;
in7 <= 13;
in8 <= 8;
wait for 50ns;
---------------------Third Test--------------------
in1 <= 1;
in2 <= 3;
in3 <= 11;
in4 <= 8;
in5 <= 15;
in6 <= 4;
in7 <= 6;
in8 <= 13;
wait for 50ns;
wait;
end process;
end;
Can you tell me, what I'm missing...Many thanks
Did you run it for long enough? are you sure there is no problem with the haar.vhd?
Dear Tricky,
The run length is 1000ns. Yes, when I simulate the haar.vhd in Quartus there is no problem. The outputs is obtained correctly. Below is my haar.vhd code:
LIBRARY ieee;
USE ieee.ALL;
ENTITY haar IS
PORT (
clock : IN bit;
-- Inputs
--Outputs
END haar;
ARCHITECTURE haar OF haar IS
COMPONENT reg
PORT (
clk : IN bit;
END COMPONENT;
COMPONENT adddiv
PORT (
a : IN integer RANGE -127 TO 127;
b : IN integer RANGE -127 TO 127;
clk : IN bit;
c : OUT integer RANGE -127 TO 127
END COMPONENT;
COMPONENT difference
PORT (
clk : IN bit;
END COMPONENT;
SIGNAL out_r1, out_r2, out_r3, out_r4, out_r5, out_r6, out_r7,
out_r8, out_r9, out_r10, out_r11, out_r12, out_r13, out_r14,
out_r15, out_r16, out_r17, out_r18, out_r19, out_r20, out_r21,
out_r22, out_r23, out_r24 : integer RANGE -127 TO 127;
SIGNAL out_a1, out_a2, out_a3, out_a4, out_a5, out_a6, out_a7 : integer RANGE -127 TO 127;
SIGNAL out_s1, out_s2, out_s3, out_s4, out_s5, out_s6, out_s7 : integer RANGE -127 TO 127;
SIGNAL clk : bit;
BEGIN
-- Input to Register 1
r1: reg
PORT MAP ( in1, clk, out_r1 );
r2: reg
PORT MAP ( in2, clk, out_r2 );
r3: reg
PORT MAP ( in3, clk, out_r3 );
r4: reg
PORT MAP ( in4, clk, out_r4 );
r5: reg
PORT MAP ( in5, clk, out_r5 );
r6: reg
PORT MAP ( in6, clk, out_r6 );
r7: reg
PORT MAP ( in7, clk, out_r7 );
r8: reg
PORT MAP ( in8, clk, out_r8 );
-- Input to Add_Divide and Difference for stage 1
a1: adddiv
PORT MAP ( out_r1, out_r2, clk, out_a1 );
a2: adddiv
PORT MAP ( out_r3, out_r4, clk, out_a2 );
a3: adddiv
PORT MAP ( out_r5, out_r6, clk, out_a3 );
a4: adddiv
PORT MAP ( out_r7, out_r8, clk, out_a4 );
s1: difference
PORT MAP ( out_r1, out_r2, clk, out_s1 );
s2: difference
PORT MAP ( out_r3, out_r4, clk, out_s2 );
s3: difference
PORT MAP ( out_r5, out_r6, clk, out_s3 );
s4: difference
PORT MAP ( out_r7, out_r8, clk, out_s4 );
--Input to Register 2
r9: reg
PORT MAP ( out_a1, clk, out_r9 );
r10: reg
PORT MAP ( out_a2, clk, out_r10 );
r11: reg
PORT MAP ( out_a3, clk, out_r11 );
r12: reg
PORT MAP ( out_a4, clk, out_r12 );
r13: reg
PORT MAP ( out_s1, clk, out_r13 );
r14: reg
PORT MAP ( out_s2, clk, out_r14 );
r15: reg
PORT MAP ( out_s3, clk, out_r15 );
r16: reg
PORT MAP ( out_s4, clk, out_r16 );
-- Input to AddDiv and Difference for stage 2
a5: adddiv
PORT MAP ( out_r9, out_r10, clk, out_a5 );
a6: adddiv
PORT MAP ( out_r11, out_r12, clk, out_a6 );
s5: difference
PORT MAP ( out_r9, out_r10, clk, out_s5 );
s6: difference
PORT MAP ( out_r11, out_r12, clk, out_s6 );
--Input to Register 3
r17: reg
PORT MAP ( out_a5, clk, out_r17 );
r18: reg
PORT MAP ( out_a6, clk, out_r18 );
r19: reg
PORT MAP ( out_s5, clk, out_r19 );
r20: reg
PORT MAP ( out_s6, clk, out_r20 );
r21: reg
PORT MAP ( out_r13, clk, out_r21 );
r22: reg
PORT MAP ( out_r14, clk, out_r22 );
r23: reg
PORT MAP ( out_r15, clk, out_r23 );
r24: reg
PORT MAP ( out_r16, clk, out_r24 );
--Input to AddDiv and Difference for stage 3
a7: adddiv
PORT MAP ( out_r17, out_r18, clk, out_a7 );
s7: difference
PORT MAP ( out_r17, out_r18, clk, out_s7 );
--Input to Register 4
r25: reg
PORT MAP ( out_a7, clk, out1 );
r26: reg
PORT MAP ( out_s7, clk, out2 );
r27: reg
PORT MAP ( out_r19, clk, out3 );
r28: reg
PORT MAP ( out_r20, clk, out4 );
r29: reg
PORT MAP ( out_r21, clk, out5 );
r30: reg
PORT MAP ( out_r22, clk, out6 );
r31: reg
PORT MAP ( out_r23, clk, out7 );
r32: reg
PORT MAP ( out_r24, clk, out8 );
END haar;
Where's I'm wrong? Many thanks
It is your job to itentify where the problem is. Check all the internal signals using modelsim. Trace the path through the design to find out where the error is occuring.
Just noticed - you dont have a clock generated. Thats probably your problem.
Dear Tricky,
Okay, I will. Many thanks
