I used quatus2 to do some a decoder, but it couldn't work when it was at the process of vector waveform file...who can help me ??:p which process is wrong?
here is the test.. module decoder(clken,code,reset,decode); input clken; input [2:0]code; input reset; output [7:0] decode; reg[7:0] decode; always @(code) begin if(reset) decode<=8'b11111111; else if(clken) case (code) 3'b000: decode <= 8'b01111111; 3'b001: decode <= 8'b10111111; 3'b010: decode <= 8'b11011111; 3'b011: decode <= 8'b11101111; 3'b100: decode <= 8'b11110111; 3'b101: decode <= 8'b11111011; 3'b110: decode <= 8'b11111101; 3'b111: decode <= 8'b11111110; endcase //表结束 end endmoduleLink Copied
