21615 Discussions
turning off and on the two 7 segment --- help
hi, I need help with quartus II 9
I should create two verilog files :
1. turn off
2. turn on
two 7 segments that display in Altera FPGA's boards
I tried some codes in the net but it's not working :(
I hope you can help me :(
Why are you using quartus 9? Quartus is now 15.
What is not working? Does it compile? Does it upload? Can you share?
--- Quote Start ---
--- Quote End ---
I know 9 is old and there is newer version, but my college use 9 , so I should use the same one for my project
when I googling I found a verilog code that turn off the 7 segment led, but unfortunately when I simulate it shows alot of errors :(
I think you posted this in the wrong section of the forum. It should have been asked in "Coding Questions -> Verilog and System Verilog". Furthermore, we can't help you unless you share the code with us. What FPGA are you using? What dev kit?
~fade
I'm really sorry, I thought it's the right section for my question,
I decide to turn it off and on by using ROM since it's easier, thanks for your concern :)
if I face any problem I will come again :)
