21602 Discussions
unable to display state transition due to long processing time
i'm trying to work with the FSM viewer on a program that contains only 3 states and all i got is :"unable to display state transition due to long processing time"
i cant figure out what is the problem ??
maybe somone got a clue ??
the program is :
LIBRARY ieee;
USE ieee.std_logic_1164.all;
-- Entity Declaration
ENTITY Baud_Rate IS
-- {{ALTERA_IO_BEGIN}} DO NOT REMOVE THIS LINE!
PORT
Ser_Data : IN STD_LOGIC;
Reset : IN STD_LOGIC;
Clk : IN STD_LOGIC;
Baud_Rate_Clk : OUT STD_LOGIC
-- {{ALTERA_IO_END}} DO NOT REMOVE THIS LINE!
END Baud_Rate;
-- Architecture Body
ARCHITECTURE Baud_Rate_architecture OF Baud_Rate IS
TYPE State IS (Initial,First_Bit, Baud_Calc,Jump,Next_Pkg,Sample,Output_Clk);
SIGNAL Cur_State : State;
BEGIN
PROCESS (Clk,Reset,Ser_Data)
------------------------------Initialization Of Variables --------------------------------
VARIABLE Int_Clk: INTEGER RANGE 0 TO 50000 :=0;
VARIABLE Ticks_Count : INTEGER RANGE 0 TO 50000 :=0;
VARIABLE Bit_Count : INTEGER RANGE 0 TO 50000 :=0;
BEGIN
IF (Reset='0') THEN
Baud_Rate_Clk<='0';
Int_Clk:=0;
Ticks_Count:=0;
Bit_Count:=0;
Cur_State <=Initial;
ELSIF ( clk'EVENT AND clk='0') THEN
CASE Cur_State IS
------------------ Variable Initializations And 'Start' Acceptence -------------------------
WHEN Initial=>
Int_Clk:=0;
Ticks_Count:=0;
Bit_Count:=0;
IF (Ser_Data='0') THEN
Cur_State <=First_Bit;
else Cur_State <=Initial;
END IF;
------------------- First Bit Acceptence ------------------------------------------------
WHEN First_Bit=>
Int_Clk:=0;
Ticks_Count:=0;
Bit_Count:=0;
IF (Ser_Data='1') THEN
Cur_State <=Baud_Calc;
END IF;
---------------------- Baud Rate Calculation ------------------------------------
WHEN Baud_Calc =>
Int_Clk:=Int_Clk+1;
ELSE
Ticks_Count:=0;
Bit_Count:=0;
Cur_State <=Jump;
END IF;
---------------------Skips the '31h' -------------------------------------------------------------
WHEN Jump=>
IF ( Bit_Count<10) THEN
Baud_Rate_Clk<='0';
IF (Ticks_Count < Int_Clk ) THEN
Ticks_Count:=Ticks_Count +1;
ELSE
Bit_Count:=Bit_Count+1;
Ticks_Count:=0;
END IF;
ELSE
Cur_state<= Next_Pkg;
END IF;
---------------------Recives The Next Package And Test It ----------------------------------------
WHEN Next_Pkg=>
Baud_Rate_Clk<='0';
Cur_State<=Sample;
Bit_Count:=0;
Ticks_Count:=0;
Baud_Rate_Clk<='0';
END IF;
---------------------Sample In The Middle Of the Bit ----------------------------------------
WHEN Sample=>
IF( Ticks_Count<(Int_Clk/2)) THEN
Ticks_Count:=Ticks_Count+1;
ELSE
Cur_state<=Output_Clk;
Bit_Count:=0;
Ticks_Count:=0;
Baud_Rate_Clk<='0';
Baud_Rate_Clk<='1';
END IF;
---------------------Creating The New Clk for the Reciver Sample ----------------------------------------
WHEN Output_Clk=>
IF( Bit_Count<12) THEN
IF(Ticks_Count<Int_Clk) THEN
Baud_Rate_Clk<='0';
ELSE
Ticks_Count:=0;
Bit_Count:= Bit_Count+1;
Baud_Rate_Clk<='1';
END IF;
ELSE
Cur_state<=Next_Pkg;
Baud_Rate_Clk<='0';
END IF;
WHEN OTHERS=>NULL;
END CASE;
END IF;
END PROCESS;
END Baud_Rate_architecture;
(this one has more than 3 states , but also on 3 states it aint working ....)
--- Quote Start ---
--- Quote End ---
I could open your statemachine with Quartus Web 7.0. I looks like that you found a bug in Quartus x.x. You should file a service request.
Kind regards
GPK
its aint working on the 9 addition ....really strange
Cr***y Quartus :D ... even version 9.1SP2, this thing still can't work properly.
--- Quote Start ---
--- Quote End ---
did you file a service request ?
Kind regards
GPK
--- Quote Start ---
Kind regards
GPK
--- Quote End ---
I will .... together with the "outdated processes" on the process panel :D
Btw, I think Altera has a IP design team, they should've spotted these way earlier.
Nvm, I'll report.
i filled , still waiting for an answer...
Is there any new update to this? I have the same problem concerning my 85-state state machine.
