21600 Discussions
unhosted baremetal boot
I'm tring to boot a baremetal application from uboot. I linked my application with a script like the one in examples (altera-socfpga-hosted.ld) whith following modifications:
line 23: GROUP(-lgcc -lc -lcs3 -lcs3hosted -lcs3arm)
to GROUP(-lgcc -lc -lcs3 -lcs3unhosted -lcs3arm)
and
line 28: ram (rwx) : ORIGIN = 0x02000000, LENGTH = 32M
ram (rwx) : ORIGIN = 0x01000000, LENGTH = 32M
running the application from debugger all works fine.
When I try to run the application from u-boot with the following commands:
fatload mmc 0:2 0x01000000 myApp.bin
go 0x01000000
or
go 0x01000040
the command fail with this error:
# # Starting application at 0x01000000 ...
data abort
MAYBE you should read doc/README.arm-unaligned-accesses
pc : [<3ff8223c>] lr : [<01000198>]
sp : 3ff4f63c ip : 00000083 fp : 00000000
r10: 00000002 r9 : 00000000 r8 : 3ff4ff60
r7 : 3ffbb8c4 r6 : 01000000 r5 : 3ff505fc r4 : 00000002
r3 : 01000000 r2 : 3ff505fc r1 : 010001d0 r0 : 60000153
Flags: nZCv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
running a readelf in a linux shell the result is:
readelf -h myApp.elf
ELF Header:
Magic: 7f 45 4c 46 01 01 01 00 00 00 00 00 00 00 00 00
Class: ELF32
Data: 2's complement, little endian
Version: 1 (current)
OS/ABI: UNIX - System V
ABI Version: 0
Type: EXEC (Executable file)
Machine: ARM
Version: 0x1
Entry point address: 0x1000040
Start of program headers: 52 (bytes into file)
Start of section headers: 399332 (bytes into file)
Flags: 0x5000002, has entry point, Version5 EABI
Size of this header: 52 (bytes)
Size of program headers: 32 (bytes)
Number of program headers: 2
Size of section headers: 40 (bytes)
Number of section headers: 20
Section header string table index: 17
What is wrong?
Thank you
Nicola
