21611 Discussions
use 2 srams at the same time
hi:
I have writen some fixed data (1.2.3...) into a sram,then I want to read the data from it and write the data into the other sram at the same time.I write the code as below:
begin
SR1_wr_n<=1;
SR1_addr<=SR2_addr+1;
SR2_wr_n<=0;
SR2_addr<=SRAM_addr+1;
end
assign SR2_DQ = (~SR2_wr_n)? SR1_DQ;16'bzzzz;
then I look at the signaltapII waveform:
I am sure I have write sram 1 correctly,but when I read the data from it,the data at adress1 should be 1,2,3...but it is 0422h,0423h,0424h...
I am not sure if the method I used the two srams is right,that is ,reading one sram and write the other sram at the same time??
I give the attachment~
thanks very much!
Please first try writing and reading only one sram properly. Make the display type according to your requirement, like HEX, Decimal, binary etc...
thanks for you answer!!~
I have find the reason,that is ,I have mistake the adress of SRAM
