21602 Discussions
use verlog ip in vhdl
I'm trying to use a verilog ip in a vhdl file, first component declaration , then instantiation ... But I keep getting : design library work does not contain ... although I added the file to my project ?
What am I doing wrong ?
architecture arch of touchtop_01 is ... component i2c_touch_config is port ( iCLK : out std_logic ; iRSTN : out std_logic ; iTRIG : out std_logic ; oREADY : in std_logic; oREG_X1 : in std_logic_vector(9 downto 0); oREG_Y1 : in std_logic_vector(8 downto 0); oREG_X2 : in std_logic_vector(9 downto 0); oREG_Y2 : in std_logic_vector(8 downto 0); oREG_TOUCH_COUNT : in std_logic_vector(1 downto 0); oREG_GESTURE : in std_logic_vector(7 downto 0); I2C_SCLK : in std_logic; I2C_SDAT : inout std_logic ); end component ; begin terasictouch : entity work.i2c_touch_config port map ( iCLK => iCLK , iRSTN => iRSTN, iTRIG => iTRIG, oREADY => oREADY, oREG_X1 => oREG_X1, oREG_Y1 => oREG_Y1, oREG_X2 => oREG_X2, oREG_Y2 => oREG_Y2, oREG_TOUCH_COUNT => oREG_TOUCH_COUNT, oREG_GESTURE => oREG_GESTURE, I2C_SCLK => I2C_SCLK, I2C_SDAT => I2C_SDAT ) ; ...
--- Quote Start ---
--- Quote End ---
Have you added the i2c_touch_config.v source to the project?
And because you have a component declaration, you do not need to use
You can just use
terasictouch : i2c_touch_config
Cheers,
Dave
--- Quote Start ---
--- Quote End ---
Should be better phrased "you must not use". Because the entity work. syntax causes the error.
Thanks a lot guys !!
Hallo!
I want to do the same but i think i've another problem.
It seems to me that the i2c_touch_config.v file isn correct. Or I'am not clever enought.
There is no effect of the output pins.
If i'm touch the screen or not, the oREG_TOUCH_COUNT always shows "11".
By the way the value "11" is not possible.
The Registers for the touchpositions are set to the maximuml value too.
Is there something i havent done ?
