21611 Discussions
using altera FPL and choosing the configuration file in real time
hi,
im using the altera pfl.
the external flash stores 4 different configuration files.
the flash is connecterd to max II cpld that responsible for the fpga configuration.
my question is how can the cpld control on which file is going to be load to the fpga.
best regards,
or shoshani
Your question is not really complete enough. What hardware platform are you using?
--- Quote Start ---
--- Quote End ---
im using custom hardware, the hardware consists of :
External cpu,
ArriaV gx FPGA ,
Max II cpld
512 mb parallel spansion flash,
the flash is connected to the max II cpld , the the CPLD is connected to the configuration pins of the Arria.
i whould like to store 4 different FPGA configuration files in the flash . and the cpu through the cpld can choose which configuration file is going to be loaded to the fpga.
You need to provision the bottom boot address into the CPLD before you initiate the FPGA boot. Assuming you have some connections from the cpu to the CPLD then you can use these to indicate which boot image to use. Alternatively, you may have jumpers connected to the CPLD with which you can specify the image you wish to boot the FPGA with. Either way, you will have to write some code for the CPLD to interpret the cpu signals or jumpers and provision one of four boot addresses.
The CPLD will then read the data directly from the FLASH, starting from your provisioned base address, delivering the bitstream to the FPGA via the configuration pins.
Alex
