21603 Discussions
using assembly macro in inline assembly in C
Hi all,
I want to use inline assembly in my code.
I understand that the syntax should be:
asm("<instruct1>;
<instruct2>;
<instruct3>;
My problem is that many NIOS II instructions are defines as pseudo-instructions (for instance movi, movia...) and also use assembler macros (for instance %lo, %hi....) and I don't know how to use them with the asm("") function. In other words:
asm("movia r2,1;
movia r3,2;");
won't work because the GCC compiler will not recognize the pseudo-instruction movia defined in the file: nios_macros.s.
If I try to include the file "nios_macros" writing: .include "nios_macros.s" in the c file, it does not work.
What should I do?
Thank you in advance,
Mike
