configuration cfg_sine_wave_tb of sine_wave_tb is
for bench for uut: sine_wave use entity work.sine_wave(arch1); end for; end for; end cfg_sine_wave_tb; this code is a test bench for a sine wave generator....but i dont understand exactly how this test bench works.....sine_wave_tb is as follows: library IEEE; use IEEE.Std_logic_1164.all; use IEEE.Numeric_Std.all; use work.sine_package.all; entity sine_wave_tb is end; architecture bench of sine_wave_tb is component sine_wave port( clock, reset, enable: in std_logic; wave_out: out sine_vector_type); end component; signal clock, reset, enable: std_logic; signal wave_out: sine_vector_type; constant clock_period: time := 10 ns; signal stop_the_clock: boolean; begin uut: sine_wave port map ( clock, reset, enable, wave_out ); stimulus: process begin -- Put initialisation code here enable <= '0'; reset <= '1'; wait for 5 ns; reset <= '0'; wait for 5115 ns; enable <= '1'; -- Put test bench stimulus code here wait for 1 ms; stop_the_clock <= true; wait; end process; clocking: process begin while not stop_the_clock loop clock <= '1', '0' after clock_period / 2; wait for clock_period; end loop; wait; end process; end; to be specific...i wanna knw....wat does "for utt:sine_wave" mean...??!!Link Copied
This isn't Verilog, it's VHDL.
In VHDL you can define several architectures for the same block, for example a RTL architecture for synthesis and a functional one for test benches. The VHDL configuration block is used to tell the simulator what architecture to use. You can find more information about VHDL configurations here (http://www.doulos.com/knowhow/vhdl_designers_guide/configurations_part_1/)
