Hi guys!, Can I simplify the followingin Verilog?:
always@(k) case(k) 0: send_char = node[7+8*0:8*0]; 1: send_char = node[7+8*1:8*1]; 2: send_char = node[7+8*2:8*2]; 3: send_char = node[7+8*3:8*3]; 4: send_char = node[7+8*4:8*4]; 5: send_char = node[7+8*5:8*5]; 6: send_char = node[7+8*6:8*6]; 7: send_char = node[7+8*7:8*7]; 8: send_char = node[7+8*8:8*8]; 9: send_char = node[7+8*9:8*9]; endcase I thought of something like: always@(k) for(i=0; i<10; i=i+1) if(i==k) send_char = node[7+8*i:8*i]; But this does not work, because "k is not a parameter". Thanks for your help! DavidLink Copied
Try this:
assign send_char = node[(k*8) +: 8];- Mark as New
Thanks, that did the trick!
The assignment "node[start +: width]" specifies start and width of the sub-vector. always@(k) for(i=0; i<10; i=i+1) if(i==k) send_char = node[(i*8) +: 8];- Mark as New
Curious to know the need for that extra for loop. If you use signal k itself as the start index, you can code:
always@(k) send_char = node[{k,3'b0} +: 8];- Mark as New
Thanks, that also works and is only two lines!
