21612 Discussions
vhdl 4 bit 7 segment display
hello,
How to display BCD in 7-segment. i'm trying to display clock value on 4 7segment displays via bcd to 7 segment decoder(4511n). any can someone tell whats going wrong. 7 segment do not display any values!
library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity DIGI_KLOK is port ( Dselect : in std_logic; D_Display : in std_logic_vector(3 downto 0); D_Select : out std_logic_vector(3 downto 0) ); end DIGI_KLOK; component Tijd_Converter port ( Con_In_m : integer range 0 to 59; Con_In_h : integer range 0 to 23; Con_out_1, Con_out_2, Con_out_3, Con_out_4 : out std_logic_vector(0 to 3) ); end component; architecture Behavioral of DIGI_KLOK is signal Clock : std_logic := '0'; signal teller : integer := 1; signal second : integer range 0 to 59; signal minute : integer range 0 to 59; signal hour : integer range 0 to 23; signal Output_1, Output_2, Output_3, Output_4 : std_logic_vector(3 downto 0); component Updade_Display port ( D_Display : in std_logic_vector(3 downto 0); D_Select : out std_logic_vector(3 downto 0) ); end component; begin process(Dselect) begin if rising_edge(Dselect) then teller <= teller + 1; if(teller = 5000000) then Clock <= not Clock; teller <=1; end if; end if; end process; process(Clock) begin if(Clock'event and Clock='1') then second <= second + 1; if(second = 59) then minute <= minute + 1; if(minute = 59) then hour <= hour + 1; minute <= 0; if(hour = 23) then hour <= 0; end if; end if; end if; end if; end process; Block_Converter: Tijd_Converter port map (Input_1, Input_2, Output_1, Output_2, Output_3, Output_4); Block_PinOuts0: Updade_Display port map (Output_1, D_Select); Block_PinOuts1: Updade_Display port map (Output_2, D_Select); Block_PinOuts2: Updade_Display port map (Output_3, D_Select); Block_PinOuts3: Updade_Display port map (Output_4, D_Select); end Behavioral; library ieee; use ieee.std_logic_1164.all; -- -------------------------------------------------------------------------- entity Updade_Display is port ( D_Display : in std_logic_vector(3 downto 0); D_Select : out std_logic_vector(3 downto 0) ); end Updade_Display; -- -------------------------------------------------------------------------- architecture Behavior of Updade_Display is begin D_Select <= "0000" when (D_Display = "0000") else -- 0 "0001" when (D_Display = "0001") else -- 1 "0010" when (D_Display = "0010") else -- 2 "0011" when (D_Display = "0011") else -- 3 "0100" when (D_Display = "0100") else -- 4 "0101" when (D_Display = "0101") else -- 5 "0110" when (D_Display = "0110") else -- 6 "0111" when (D_Display = "0111") else -- 7 "1000" when (D_Display = "1000") else -- 8 "1001" when (D_Display = "1001") else -- 9 null; end Behavior; library ieee; use ieee.std_logic_1164.all; -- -------------------------------------------------------------------------- entity Tijd_Converter is port ( Con_In_m : integer range 0 to 59; Con_In_h : integer range 0 to 23; Con_out_1, Con_out_2, Con_out_3, Con_out_4 : out std_logic_vector(0 to 3) ); end Tijd_Converter; -- -------------------------------------------------------------------------- architecture Behavior of Tijd_Converter is begin process(Con_In_m, Con_In_h) begin if Con_In_m = 0 then Con_out_3 <= "0000"; Con_out_4 <= "0000"; Con_out_1 <= "0000"; Con_out_2 <= "0000"; elsif Con_In_m = 1 then Con_out_1 <= "0001"; Con_out_2 <= "0000"; elsif Con_In_m = 2 then Con_out_1 <= "0010"; Con_out_2 <= "0000"; elsif Con_In_m = 3 then Con_out_1 <= "0011"; Con_out_2 <= "0000"; elsif Con_In_m = 4 then Con_out_1 <= "0100"; Con_out_2 <= "0000"; elsif Con_In_m = 5 then Con_out_1 <= "0101"; Con_out_2 <= "0000"; elsif Con_In_m = 6 then Con_out_1 <= "0110"; Con_out_2 <= "0000"; elsif Con_In_m = 7 then Con_out_1 <= "0111"; Con_out_2 <= "0000"; elsif Con_In_m = 8 then Con_out_1 <= "1000"; Con_out_2 <= "0000"; elsif Con_In_m = 9 then Con_out_1 <= "1001"; Con_out_2 <= "0000"; elsif Con_In_m = 10 then Con_out_1 <= "0000"; Con_out_2 <= "0001"; elsif Con_In_m = 11 then Con_out_1 <= "0001"; Con_out_2 <= "0001"; elsif Con_In_m = 12 then Con_out_1 <= "0010"; Con_out_2 <= "0001"; elsif Con_In_m = 13 then Con_out_1 <= "0011"; Con_out_2 <= "0001"; elsif Con_In_m = 14 then Con_out_1 <= "0100"; Con_out_2 <= "0001"; elsif Con_In_m = 15 then Con_out_1 <= "0101"; Con_out_2 <= "0001"; elsif Con_In_m = 16 then Con_out_1 <= "0110"; Con_out_2 <= "0001"; elsif Con_In_m = 17 then Con_out_1 <= "0111"; Con_out_2 <= "0001"; elsif Con_In_m = 18 then Con_out_1 <= "1000"; Con_out_2 <= "0001"; elsif Con_In_m = 19 then Con_out_1 <= "1001"; Con_out_2 <= "0001"; elsif Con_In_m = 20 then Con_out_1 <= "0000"; Con_out_2 <= "0010"; elsif Con_In_m = 21 then Con_out_1 <= "0001"; Con_out_2 <= "0010"; elsif Con_In_m = 22 then Con_out_1 <= "0010"; Con_out_2 <= "0010"; elsif Con_In_m = 23 then Con_out_1 <= "0011"; Con_out_2 <= "0010"; elsif Con_In_m = 24 then Con_out_1 <= "0100"; Con_out_2 <= "0010"; end if; end process; end Behavior;
Which is top calling which vhdl component. Why commented out components and where is output_1 etc. Needs a lot of explanations and wouldn't compile !!
DIGI_KLOK is top level, please review my first post, I have modify it.
Before you go further there are still fundamental errors in the program structure, among them: you should declare both components in the architecture of top level. secondly you cannot drive D_select four times.
