Programmable Devices
21610 Discussions
wait statement inside process
Hi all,
I faced some problem when I trying to compile my following code. The error replied was only one wait statement is allowed in the process. I have tried putting IF statement but it took 10,000 iterations. May I know how can i change my code?
Main : process
variable counter : counter_type := 0;
begin
-- HWY green, SRD red
wait on (CLOCK until CLOCK = '1' and SRDcar = '1');
if (HWYcar = '1') then
Counter := 0;
loop
wait until CLOCK = '1';
exit when (HWYcar = '0' or Counter = long_cycle);
Counter := Counter + 1;
end loop;
end if ;
Thank you so much
Main : process
begin
if rising_edge(CLOCK) then
if SRDcar = '1' then
if HWYcar = '1' then
counter := 0;
elsif counter = long_cycle then
null;
else
counter := counter + 1;
end if;
end if;
end if;
end process;
I think this should be something like what you want.
Ben
thank you ben. but the error return now is rising_edge is used but not declared. sorry for bothering. I'm very very new this software.
Have you included the std_logic_1164 library because that is where the rising_edge function is declared.
use ieee.std_logic_1164.all;
yup... i included that...
library ieee;
was trying to figure this out for the past 2 days...
You can replace "if rising_edge(CLOCK) then" with "if CLOCK'event and CLOCK = '1' then" or you open the std_logic_1164 library and check that the rising_edge function is in there.
thank you so much for yr help mate. good luck :)
--- Quote Start ---
--- Quote End ---
You might benefit from references suggested at http://www.alteraforum.com/forum/showthread.php?t=1025. Start with the coding style guidelines in the Quartus handbook and the examples in the Quartus text editor templates.
