21611 Discussions
web server demo program execution using De2 115 board
hi
I am trying to run web server demo program on cyclone Iv E DE2 115 kit. can someone give me detailed steps on how to do the same??
Thanking in advance
veer
--- Quote Start ---
hi
Thanking in advance
veer
--- Quote End ---
I hope you are able to select Ethernet Mode MII/RGMII by selecting JP1 or JP2 ETHERNET0 and ETHERNET1. If you get any error, please follows the below link.
http://www.alteraforum.com/forum/showthread.php?t=27115
Thanks to kkr. I followed the steps and i am getting the following error when i try to build my project.
make -s all includes
Creating system.h...
Jan 28, 2014 12:51:46 PM - (SEVERE) generate: java.lang.IllegalStateException: java.lang.IllegalStateException: java.lang.NumberFormatException: empty String
make[1]: *** [system_description/../obj/system.h-t] Error 1
make: *** [system_project] Error 2
Build completed in 48.531 seconds
Anyone who has resolved this problem plz reply.... thnx in advance........
--- Quote Start ---
--- Quote End ---
Hi Veer,
You are welcome. It looks like you have Java path error. Please check your java environment path and try to fix it. I hope you are using NIOS II Command Shell instead NIOS II BST.
Hi KKR,
We are making use of NIOS-II IDE , not NIOS_II Command shell. Would that be a problem?
Please reply me the steps to fix that JAVA path ERROR.
--- Quote Start ---
Hi KKR,
--- Quote End ---
Hi veer,
Try to use NIOS II Command Shell, as you already have commands in one of previous thread. I finished few months back on same DE2-115 board, but with MII inference. Hope, it will be the same for you.
Hi kkr,
Hey i was able to run the web server demo program thnk u very much.........
--- Quote Start ---
Hi kkr,
--- Quote End ---
That's great. You are welcome.
