I want to know what is the function of cyclone_lcell?
Where can I find the description of its parameter like the following? parameter output_mode = "reg_and_comb"; parameter operation_mode = "normal"; parameter synch_mode = "off"; parameter lut_mask = "unused"; parameter register_cascade_mode = "off"; parameter sum_lutc_input = "datac"; parameter cin_used = "false"; ...Link Copied
Some information can be found in the User Guide designing with low-level primitives. For Stratix FPGA families, more information in the advanced synthesis cookbook.
