21602 Discussions
why the simulation result is differenct between fork join and begin end?
this is the testbench in an495.
why can not use begin ... end.
initial
begin
arst <= 1'b0; // resetting the contoller initially
# 250
arst <= 1'b1;
iderst <= 1'b0;
ideen <= 1'b1;
pioiordyen <= 1'b1;
piorqst <= 1'b1;
pioaddr <= 4'b0111;
piodatain <= 16'b1111111100000000;
piowe <= 1'b1;
# 600 piowe <= 1'b0;
ddi <= 16'b0000000011111111;
iordy <= 1'b1;
intrq <= 1'b1;
flag <= 1'b0; //if error occured in the test procedure,then asserted
# 5000
$stop;
end
use the fork join,the result is right
fork
arst = 1'b0; // resetting the contoller initially
# 250
arst = 1'b1;
iderst = 1'b0;
ideen = 1'b1;
pioiordyen = 1'b1;
piorqst = 1'b1;
pioaddr = 4'b0111;
piodatain = 16'b1111111100000000;
piowe = 1'b1;
# 600 piowe = 1'b0;
ddi = 16'b0000000011111111;
iordy = 1'b1;
intrq = 1'b1;
flag = 1'b0; //if error occured in the test procedure,then asserted
# 5000
$stop;
join
The difference between "begin-end" and "fork-join" is that in initial block "begin-end" operations work step-by-step, but in "fork-join" they work simultaneously. You can rewrite the testbench using "begin-end". For example,
begin
iderst <= 1'b0;
ideen <= 1'b1;
pioiordyen <= 1'b1;
piorqst <= 1'b1;
pioaddr <= 4'b0111;
piowe <= 1'b1;
iordy <= 1'b1;
intrq <= 1'b1;
# 250 arst <= 1'b1;
# 350 piowe <= 1'b0;
# 4400 $stop;
end
I believe, it will work like original "fork-join"
The begin-end-block also assigns the values to the nets simultaneously if non-blocking assignments are used (as it's the case in the example). The difference is that all timing assignments are with respect to the block entry time in case of fork-join and with respect to the previous timing assignment in case of begin-end.
