21607 Discussions
write code for schematic diagram
hi!
I HAVE A cmos JK 807A CAMERA:
number of pixel: 628(h)x582(v)<PAL>,
Resolution:380 lines.
scaning frequency:50 Hz
min.lllumination: 0.2~3 Lux
S/N ratio : 40db
white balance : Auto
video output 1.0 Vpp composite 75ohm
power supply:Dc 9v.
my project is "Real time video capture and image processing using fpga".
i plan for edge detection of the input video or brightness control of
the video.i make a block schematic for my work.can u write vhdl code for the block schematic.also tell me is it possible with that camera or not.Can You help me!!!!!
From your camera specs I assume that you have a composite video output camera. So you should best use an FPGA board with a video codec on board. The de2 board (http://de2.terasic.com)is an excellent platform for your project. The board also has worked out examples using such a camera. You should of course update the provided designs for your project.
--- Quote Start ---
hi!
--- Quote End ---
The relation of your composite video camera with the (incomplete) block diagram that you have drawn is unclear.
if u have any reference design or any useful material for my work please provide me.
--- Quote Start ---
--- Quote End ---
--- Quote Start ---
--- Quote End ---
Please have a look at the de2 (http://de2.terasic.com) reference designs and documentation. It is all in there
