Rapid Storage Technology
Intel® RST, RAID
无法接接收预警邮件
Hank_Wang
英特尔快速存储技术的邮件预警无法设置成功,详见附件
VonM_Intel
Hi, Hank_Wang.
请注意,我只能用英语为您提供支持。我使用了网络翻译工具来翻译此回复,因此,可能会有一些不准确的翻译。
Thank you for posting in our Community and for providing the screenshot of the email test failure. I understand that you're experiencing difficulties configuring the email alert function within Intel® Rapid Storage Technology (Intel® RST). Based on your report, it appears the issue is related to the alert email settings not being successfully applied.
To better assist you, please help me confirm the following:
  • Does the error occur immediately when testing the email alert, or after a delay?
  • Have you tried using a different email address or service for testing? If yes, what was the result?
Additionally, if you have done any other tests, please let me know the details so we don't cover the same ground twice.
Have a nice day!
Von M.
VonM_Intel
Hello, Hank_Wang.
Von M.
Hank_Wang
Hi
Thank you for your reply.
I tried using another email address, but it still didn't work. Normally, this setup requires entering the email password, but i can't find the password field. Please see the screenshot below for more information.
another email addressanother email address
VonM_Intel
Hello, Hank_Wang.
Thank you for the update and for sharing the screenshot. Based on your description, it appears the email setup process may be skipping the password entry step, which could be due to one of the following:
  • A misconfiguration in the account type or authentication method
  • A missing or unsupported password prompt due to system or application behavior
I will need to do further research on this matter and post the response on this thread once available.
Von M.
VonM_Intel
Hello, Hank_Wang.
Thank you for patiently waiting and for sharing the screenshot. Upon reviewing it, I’m unable to fully understand the exact message in the pop-up notification. To proceed accurately, could you please either translate the notification or change your computer's language to English? This will help us capture the exact message. You can follow the instructions in this link to change the language: Microsoft Support - Change Language Settings.
Once I have the translated notification or English version, we can continue troubleshooting and work towards resolving the issue. Thank you for your cooperation!
Von M.
VonM_Intel
Hello, Hank_Wang.
Von M.
VonM_Intel
Hello, Hank_Wang.
Since I haven’t heard back from you, I’ll go ahead and close this inquiry for now. If you need any further assistance in the future, please don’t hesitate to submit a new question, as this thread will no longer be monitored.
Von M.
Hank_Wang
Let me know if you need anything else. Thanks!
Kiriakos-GR
Windows 7 does not come with a native SMTP service.
You need to buy thrird-party software and set up another outgoing server to send your emails.
For example at Microsoft Outlook 2010, if you select SMTP account instead of POP3.
The software ...  Microsoft Outlook 2010 ... this will create the necessary windows service environment,  so this alone  to work with it.
Native SMTP service, this is supported only at SERVER edition of Windows.
Your current operating system this supports only workstation PC.
INTEL RST email notifications this does not work with workstation PC.
Hank_Wang
Same Server, same settings , just different software , and it is working properly.
Hank_Wang
Please see the attached system information in English.
Kiriakos-GR
Just for test ...  Disable SSL encryption for the specific account at the email server .... then test again the RST
Hank_Wang
Still not working
Kiriakos-GR
Over the years many came here asking for assistance and did not find any.
Your actual  question is : Can I send email unauthenticated to an internal SMTP server which then relays onto authenticated SMTP?
Answer: Only a professional IT with Microsoft training,  he should have relative know-How.
Read the topic bellow as help, about to find more clues by your self.
https://serverfault.com/questions/543514/can-i-send-email-unauthenticated-to-an-internal-smtp-server-which-then-relays-on
Hank_Wang
I do not have administrator rights to access the email server, and most email providers do not allow disable SSL for security reasons.
