Rapid Storage Technology
Intel® RST, RAID
2191 Discussions
16 instances of IRST running at same time - WHY?
ChaosSpectre
Can anyone tell me why i currently have 16 instances of IRST running as seen attached. I find it is bogging down my laptop.
I am currentky runing Windows 10 on an Alienware R17.
Any help would be appreciated.
AlHill
Why do you need IRST on your laptop?
Doc
ChaosSpectre
I don't know that I do. I run a hard disc and SSD, but from i understand Windows 10 installed IRST automatically.
Do you have any suggestions for the original post?​
n_scott_pearson
Windows 10 most definitely DID NOT automatically install Intel RST. Unless you are using RAID or an Optane module, you do not need Intel RST and it would be best if you completely uninstalled the package. Open the Apps and Features applet, click on the entry for Intel RST and select Uninstall.
ChaosSpectre
Excellent. thanks for the info. But does anyone know why it would run so many instances?
n_scott_pearson
Not sure; I have never seen it display more than one. I wonder if there is an icon to go with each of n outstanding error messages. Anything in the message center/event log?
What happens if you click on one of these icons? Does it cause an error message to pop up?
