Rapid Storage Technology
Intel® RST, RAID
2233 Discussions
Can I create RAID-1 volume with different interface technologies but the same capacity modules??
BSwid2
Hi, I'm speccing a new machine. It has only one M.2 slot available for an SSD. Can I use RST to create a RAID-1 volume between a 1TB module in that slot along with another 1TB module, either a SATA attached drive or a PCIE x4 slot SSD?
Amy_C_Intel1
Hello BSwid2, Thank you for posting on the Intel® Communities. Yes, you should be able to create it with that set up. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
