Rapid Storage Technology
Intel® RST, RAID
2205 Discussions
Can't enable HDD drive optimization using SSD: unknown error (0xA001004B)
JSzew
I have 2 drives: a 1TB HDD and a 58GB SSD (OCZ-Agility3). I used to optimize the HDD using the SSD and everything was working fine. Yesterday I disabled the optimization for a moment and I cannot re-enable it, because I get unknown error 0xA001004B. When I googled it, I found a reference to Optane manual, indicating that I should have at least 5MB at the end of the drive unallocated. I don't have an Optane SSD, but I freed 5GB (just in case) at the end of the drive, but this didn't help. Any ideas? HDD without SSD support sucks.
Jakub
themeo: Thank you very much for contacting the Intel® Rapid Storage Technology communities. We will do our best in order to try to fix this problem.
In order to provide the most accurate response, please provide the system report:
https://www.intel.com/content/www/us/en/support/technologies/000006351.html https://www.intel.com/content/www/us/en/support/technologies/000006351.html
Also, could you please provide a screenshot of disk management?
Any further questions, please let me know.
Alberto R
JSzew
Dear Alberto,
thanks for your willingness to help. I attached what you asked for. Please let me know if I can do anything more.
best regards,
Jakub
Hi themeo: You are welcome. Thank you very much for providing the file. In this case it looks like the SSD still have the RAID structure on it and what we need to do is to remove it. In order to do that, on the Intel® RST accelerate tab, please choose stop acceleration and then select reset to available. After that you will be able to enable the acceleration feature once again.
Alberto R
themeo: I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R
JSzew
Hi Alberto,
I tried that previously, and tried it again after your reply, but it leads to exactly the same error. Is there anything else I could do?
best wishes,
Jakub
Hi themeo: Thank you very much for letting us know that information. We will do further research on this matter in order to confirm if there is any other method to try fix this problem. As soon as I get any updates I will post all the details on this thread.
Alberto R
themeo: I just wanted to let you know that after reviewing the picture of disk management, we can see that the 5GB portion of the SSD you left clear, was not unallocated.
In order to set it as unallocated, please follow the steps below:
1- Take caution before proceeding. We recommend backing up all data.
2- Confirm your SATA disk contains 5MB of continuous unallocated space at the end of the drive.
3- You can view and modify disk setup in Disk Management (Windows Key + x > Disk Management).
3.1 - Shrink the partition at the end of the drive. Right-click the partition of the SATA system OS drive you want to accelerate. Select Shrink Volume.
3.2 - If this option is not available, the partition may not be shrinkable or there may not be space to allocate.
3.3. - (For HDDs) If there is no space, defrag the system volume to create shrinkable space.
3.4- If there is a locked partition at the end of the volume that cannot be shrunk, see How to Resize a Partition for other options.
If there is a recovery partition at the end of your system disk, it may not be movable. You may need to rebuild your OS image, but we recommend working with your OEM or motherboard vendor before proceeding.
Alberto R
JSzew
Hi Alberto,
you wrote that "we can see that the 5GB portion of the SSD you left clear, was not unallocated." - just to make sure, you meant HDD not SSD, right?
And if you meant HDD, there is 5,46GB of _unallocated_ space at the and of the disk - I already followed the procedure that you included before contacting you on the forum.
best regards,
Jakub
Hi themeo: Thank you very much for letting us know those results. Yes, as it was mentioned previously, the requirement of the unallocated space is actually 5MB on the HDD, the fact that you have 5,46GB is actually pretty good for testing purposes. Just to confirm, did you made any recent software/hardware changes on the computer, like a Windows update or upgrade?
Alberto R
JSzew
No significant changes in software/hardware. I just disabled RST acceleration for a moment to defrag the HDD and I cannot re-enable it.
themeo: Thank you very much for letting us know that information. We will continue with our research on this subject, as soon as I get any updates I will provide all the information on this thread.
Alberto R
themeo: I just received an update on the research we were doing this matter and actually the latest Intel® RST version contains the fix for the 5mb warning issue, please try to install it:
https://downloadcenter.intel.com/download/27147/Intel-Rapid-Storage-Technology-Intel-RST-?product=55 https://downloadcenter.intel.com/download/27147/Intel-Rapid-Storage-Technology-Intel-RST-?product=55
Alberto R
Alberto R
JSzew
In the meantime, I moved the disk to another computer where it serves as the system disk (so outside of IntelRST). So I cannot confirm if the new version of the software solves the problem.
best regards,
Jakub
themeo: No problem at all. Thank you very much for letting us know those details.
Alberto R
