Rapid Storage Technology
Intel® RST, RAID
2252 Discussions
Cannot install Intel Rapid Storage errorCode: 20004
DMalu
Hello support,
I'm trying to install intel rst to a machine every setup that i've runed from the HP repository for my device it failed. I attach the log.
n_scott_pearson
This is a Platform-Not-Supported error. It usually occurs when support for Intel RST is not enabled in the BIOS. If you do not plan to use either Intel RAID or Intel Optane Memory-based disk acceleration, then you do not need to install this package at all.
Hope this helps,
DMalu
I've a SSD M.2 solution in AHCI mode, and I know that it helps a lot the Intel RST.
LeonWaksman
I agree with Scott. If you are using SSD M.2 (NVME?) in SATA mode you don't need Intel RST Driver. There is no performance gain switching from AHCI to RST on a single drive. For additional information and benchmarks read this blog: https://www.win-raid.com/t362f23-Performance-of-the-Intel-RST-RSTe-AHCI-RAID-Drivers.html
Leon
