Rapid Storage Technology
Intel® RST, RAID
Degraded raid disks
MTona
Hello everyone,
I would like to ask you for help on this:
As attached screen, I have one of the two disks flagged as degraded (simply I needed to change disk letter to the disks before, and now no longer recognize them as raid)
The two disks I want to restore are those highlighted in red.
If I click on "Rebuild to another disk", will I lose the contents of both disks? Or just that who needs to be rebuilt?
Thank you so much for any help!
M
Hello, ntoniraid. Thank you very much for taking the time to reach the Intel Communities Team. I will do my best to assist you further.
In this case, since you are having a RAID1 (mirroring) on your system, both disks should have the same information. Then, since the array was degraded, when you start the rebuilding process the information from the SATA disk, which is currently not in the array; should be deleted and replaced with the information of the disk that is currently in the degraded RAID array.
Antony S.
Hello, ntoniraid.
I would like to know if you have any additional question. If so, please do not hesitate to reply to this thread.
Antony S.
