Rapid Storage Technology
Intel® RST, RAID
2190 Discussions
Deleting Raid 0 using Intel Optane Storage Mgt. Tool.
Jep
Accidently did a raid on a C: Boot drive and my new 2 TB M2 ssd.
How to remove raid 0
Diskpart doesnt work
Or the answer on other threads Ctrl I
I have Acer Predator Helios 300
No Raid option on Bios
Tried reinstalling Windows
Raid still intact
BrusC_Intel
Hello, Jep.
Thank you for contacting the Intel Community Support Forums.
I received your case regarding the Intel Optane Memory and Storage Management, and I will be reviewing this with you.
This particular tool offers different functionalities, as the name implies, some related to Optane Memory management, and other related to storage or RAID management (also known as Intel RST).
I will route your inquiry to the specialized team so they can assist you as soon as possible.
Bruce C.
Jean_Intel
Hello @Jep.
You must keep in mind that when you delete a RAID 0 the drive will be formatted and all data stored will be lost.
Follow the steps listed below, in order to delete the RAID array with Intel® Rapid Storage Technology GUI.
  • Open Intel® Rapid Storage Technology enterprise tool within Windows*
  • Click the home button and select the array
  • Under Volume properties, on the right side, you should be able to see "Delete volume"
  • Click it and then select yes
  • Once the volume has been deleted, it should be possible to see involved drives as individual drives
I hope you find this information useful.
Jean O.
Jean_Intel
Hello @Jep.
I hope you are doing fine.
Let me know if you still need assistance.
Jean O.
Jean_Intel
Hello @Jep.
We hope you are doing fine.
We have not heard back from you. So we will close this thread, if you need any additional information, please submit a new question as this thread will no longer be monitor
Best regards.
Jean O.
