Rapid Storage Technology
Intel® RST, RAID
2223 Discussions
For a few days, when I started the notebook, I got a page related to Intel Rapid Storage Thecnology. What should I do to prevent it from appearing?
PMAGN2
AdrianM_Intel
Hello PMAGN2
It would be good to check with the system manufacturer if it's possible to avoid this option ROM screen by enabling/disabling this feature from the BIOS.
Another way to try this is to reset your Disks to non-Raid however bear in mind that there is a RAID 0 configured which uses the read/write capabilities of two or more hard drives working together to maximize storage performance so there is no security.
Make sure you make a back up of all your information before making the change since all the data could be lost due to the change.
Adrian M.
n_scott_pearson
What I see is a setup where the performance of a HDD was being accelerated using the capabilities of a small SSD. At some point, the HDD was either replaced or removed from the association with the cache drive. You can use the Intel RST GUI, from Windows, to reestablish the relationship between the two drives (i.e. choose to accelerate ite performance) or you can clear the state of this SSD and use it for other purposes (though it's kind of small for any other purpose).
PMAGN2
344/5000
In reality that small SSD was a virtual HD that had been generated by HP on the original disk. I replaced the original HDD which had failed with an SSD. Obviously the BIOS was looking for this disk set as RAID. With Intel RST I canceled the RAID setting of this cashe and now everything is working properly. Thank you.
