Rapid Storage Technology
Intel® RST, RAID
Hdd disappeared!!please help
AShan5
I bought a new acer predator 15.. it has a 256gb ssd and 2tb hdd..When i started using intel rst..It created a recovery volume and now,i cant see my 2tb hdd volume in file explorer...only the ssd volume is visible in file explorer..Pleas help...
Hello Akshayshan1,
Thank you for joining this Intel Community.
I understand that Intel® RST created a recovery volume on your Acer Predator 15. I would like to provide more information about this issue.
To resolve this problem, you may need to mark the drive as non-raid in BIOS to delete the raid volume and then use it in Windows as desired.
Please follow these steps:
-During boot, use CTRL-I to enter the RST BIOS Extension.
-Mark the drive as "Non-RAID".
-Reboot your system.
It is worth mentioning that you should back up your data if needed. Also, this key combination may have been disabled by your computer manufacturer. If you are not able to enter the RAID BIOS extension, please contact your system manufacturer for more information about it.
I hope you find this information helpful.
Wanner G.
Hello Akshayshan1,
Were you able to mark the drive as non-raid in BIOS to delete the recovery volume?
If you still need any assistance, we will be glad to help you.
Wanner G.
