Rapid Storage Technology
Intel® RST, RAID
2196 Discussions
How do I revert my SSD and HDD back from a RAID 1 volume?
JJian28
I made my HDD into a recovery drive by mistake for my SSD and I want to change it back to a normal HDD. Any way to revert the RAID 1 volume?
Hello Noxap,
I can see you have a problem with your HDD.
Allow me to share with you that if you have an Intel® product like a Motherboard, Compute Stick or NUC you can simply follow the next steps in order to revert this:
  1. While your computer is posting press Ctrl + I
  2. Once you get thee you will need to set up your drives as "non raid"
  3. Reboot the system
In the other hand, if your computer or Motherboard is from any other manufacturer you might need to get in touch with them since they can change this command or make it unavailable.
Please let me know if you have any other type of question.
Antony S.
Hello Noxap,
I would like to double check if the troubleshooting steps I attached on the last post were helpful for you.
Antony S.
