Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
How to change from RAID0 to AHCI
Hello there. I have couple question. I tried google but was not successful.
I have Windows XP, BIOS set to RAID, 2 HDD, running Intel RST (Latest driver). and running fine.
Mobo is Gigabyte GA-EP35-DS3R (P35 / ICH9R)
I need to change 2 HDD RAID to 1 HDD AHCI mode.
I managed cloning 2 HDD RAID volume to 1 HDD, and Windows XP starts just fine under BIOS set to RAID.
But when I change BIOS to AHCI mode, I get 0x7B BSOD.
These are my question.
(1) How do I change Windows XP to RAID mode to AHCI mode?
(2) Any disadvantage if I keep using RAID mode in 1 HDD configuration?
Thank you!
Matthew K
Since no one answer to my questions, I googled more and tried to fix myself and I managed to fix 0x7b BSOD.
Here is what I did.
I basically followed his advice.
http://forums.pcper.com/showthread.php?t=444831 http://forums.pcper.com/showthread.php?t=444831
I had iaStor.sys in RAID mode, my registry was like this.
==== My original registry ====
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\CriticalDeviceDatabase\pci# ven_8086&dev_2822&cc_0104]
"ClassGUID"="{4D36E97B-E325-11CE-BFC1-08002BE10318}"
"Service"="iaStor"
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor]
"Type"=dword:00000001
"Start"=dword:00000000
"Group"="SCSI miniport"
"ErrorControl"=dword:00000001
"DisplayName"="Intel RAID Controller"
"ImagePath"=hex(2):73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,44,00,\
52,00,49,00,56,00,45,00,52,00,53,00,5c,00,69,00,61,00,53,00,74,00,6f,00,72,\
00,2e,00,73,00,79,00,73,00,00,00
"Tag"=dword:00000019
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters]
"queuePriorityEnable"=dword:00000000
"BusType"=dword:00000008
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port0]
"AN"=dword:00000000
"LPM"=dword:00000000
"LPMSTATE"=dword:00000000
"LPMDSTATE"=dword:00000001
"GTF"=dword:00000000
"DIPM"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port1]
"AN"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port2]
"AN"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port3]
"AN"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port4]
"AN"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\Port5]
"AN"=dword:00000000
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Parameters\oromVersion]
"MajorVersion"=dword:00000007
"MinorVersion"=dword:00000005
"HotfixNumber"=dword:00000000
"BuildNumber"=dword:000003f9
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\iaStor\Enum]
"0"="PCI\\VEN_8086&DEV_2822&SUBSYS_B0001458&REV_02\\3&13c0b0c5&0&FA"
"Count"=dword:00000001
"NextInstance"=dword:00000001
==== End of Registry ====
I deleted these registry and merged registry from website at above.
==== New registry ====
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Control\CriticalDeviceDatabase\pci# ven_8086&dev_2922&cc_0106]
"Service"="iaStor"
"ClassGUID"="{4D36E96A-E325-11CE-BFC1-08002BE10318}"
"ImagePath"="system32\\drivers\\iaStor.sys"
"tag"=dword:00000019
"DisplayName"="Intel AHCI Controller"
<span sty...
I fixed myself. I commented what I did.
