Rapid Storage Technology
Intel® RST, RAID
2213 Discussions
I'm looking for an Intel server motherboard with c600 series chips.
LeonLin
And find the RST driver of c600 series chip in win10 x64 system.Can someone help me?
JoseH_Intel
Hello LeonLin,
Thank you for joining the Intel community
Unfortunately the Intel C600 chipset has been discontinued already. Currently all server systems are been built under the C620 series chipset. You can find specifications information on this website. https://ark.intel.com/content/www/us/en/ark/products/series/98470/intel-c620-series-chipsets.html
About server products you can check under the Intel Server Edge for the very latest products available: https://servermarketinglibrary.intel.com/the-edge/
For configuration information you can check the Intel Server Configurator tool: https://serverconfigurator.intel.com/
Hope this helps
Jose A.
LeonLin
Thank you for your reply. I don't need to buy c600 series server motherboard, just because I bought ASUS C602 motherboard, but they didn't provide RSTe win10 driver. the latest one is win7.
Now I found the s2600co motherboard, downloaded his win10 rste driver, and successfully installed it.
After nearly 10 hours of initialization, only 18% was completed. I don't know if the efficiency of the C602 motherboard is so low or because the hard disk is too large? Can C602 chip hold 8tb hard disk to build RAID5?
n_scott_pearson
Yes, it really can be this slow. I have a Z87 board, an Intel DZ87KLT-75K Desktop Board, that I used to create a 3-drive RAID5 array. It took two full days to initialize the array.
LeonLin
Thank you. Can you recommend a dual channel motherboard of E5 2690 and supporting thunderbolt 3?
JoseH_Intel
Hello LeonLin,
Currently there are no dual CPU systems been manufactured by Intel that support thunderbolt connections. You will need to find out with other OEMs.
Jose A.
