Rapid Storage Technology
IntelĀ® RST, RAID
2190 Discussions
I responded to a problem with RST problem and the agent responded back because I couldn't download Windows version 1903. He wa from Costa Rico (Diego) and worked on my computer for over an hour. I am still getting the pop-up. Is this a scam
RVale10
AlHill
What pop-up? What scam? What is your current version of W10? 1809?
For the RST and 1903 issue, it is typically because of the existence of iastora.sys in the windows/system32/drivers folder. The simple solution is to rename that file to iastora.tmp, then do the 1903 upgrade. The problem is that the windows upgrade tool simply sees the file and complains. It is not that the file is actually in use.
As always, have a backup or restore point before you attempt this. And, you should upgrade to the latest RST before you start.
Since you have been in communication with an Intel support engineer, you should continue your dialog with him. If your case is more complex or does not involve the simple solution I described, your Intel support engineer will help you.
Doc
AlHill
Provide a photo of this pop-up. Windows could care less about your AOL account.
Also, HP is 100% responsible for support of your laptop.
From where are you trying to download 1903, or are you doing it from start, settings, update&security?
One last question - What processor model number do you have?
Doc
n_scott_pearson
And, LOL, Diego is from Costa Rica...😁
David_V_Intel
Hello RVale10,
Were you able to check the previous posts?
Please let me know if you still require assistance.
David V
A Contingent Worker at Intel
David_V_Intel
Hello RVale10,
Please contact us if you have any additional questions.
David V
