Rapid Storage Technology
Intel® RST, RAID
2234 Discussions
INTEL RST 14th GEN DRIVER - HELP!!!
NEWSUNSEO
Hello everyone, I am trying to install Windows 11 Pro, but I cannot find a driver so Windows can see the NVME I have installed.  These are my specs:
Windows 11 Pro
Intel Core i7-14700K
Crucial T700 CT2000T700SSD3
MSI MEG Z790 ACE
I am trying to install the Crucial NVME into the Gen5 NVME slot.  I was able to get Windows installed by moving the Crucial to one of the Gen4 slots & extracting the RST drivers, then installing them during installation.  I have been unable to find a driver to get this Crucial to install in the Gen5 slot though...  Does anyone know how to get this to work / where I can find the driver?
Thank you
LeonWaksman
1. Is the SSD recognized in BIOS when installed in M2_4 (PCIe5x4)slot?
2. Are you aware that M2_4 slot is unavailable when installing in PCI_E2 slot?
Leon
NEWSUNSEO
Hello Leon, thak you for your reply.  The NVME shows up in the BIOS when I put it into the top M.2 slot closest to the CPU (PCIe Gen 4).  I have two Samsung 990 Pro 4tb NVME's in the next two lower slots (PCIe Gen 4).  The PCIe Gen 5 slot is the bottom left one & the NVME does not show up in the BIOS when I put it into that slot.
No, I was not aware that the M2_4 slot is unavailable when installing in PCI_E2 slot.
I want to install Win 11 Pro onto the Crucial PCIe Gen 5 NVME & run that in the Gen5 slot on the motherboard.  I then wanted to have the two Samsung 990 Pro 4tb NVME's in RAID 0 running in two of the PCIe Gen 4 slots.  I have two RTX 4090's in the system also for running AI models.  How do you think I should go about getting this to work?
Thank you for your help,
NEWSUNSEO
I looked into this more...  I can either run the two 4090's & have the Crucial NVME run at PCIe Gen 4 speeds, or I can try moving the 2nd 4090 to the PCI_E3 slot & if it will fit / move whatever I have plugged into the bottom of the board somewhere else...  I will give this some thought.  Thank you VERY much for pointing this out to me Leon!
LeonWaksman
Please read the User Manual, pages 33-41 for M2 slots installation instruction and limitation. Yes, if you want to have M2_4 slot available, the PCI_E2 slot (the middle slot), have to be unoccupied. Read also the speed limitation of the PCIe slots, on page 31.
Leon
