Hello @RLuca1
- Press Power Button to switch NUC ON
- Repeatedly depress F8, you will see words: Please wait. Stop depressing F8, NUC will enter Advanced Option Menu.
- Click/tap on Troubleshoot.
- Click/tap on Advanced options.
- Click on Startup Repair. If prompted, click/tap on an administrator and follow the instruction on screen.
- If the repair will not fix the problem enter again into Advanced options screen.
- Click on Command Prompt
- In the Command Prompt write the following command: bcdedit /set {default} safeboot minimal and press enter to execute this command
- Close the Command Prompt window by clicking the X in the upper right corner of the Command Prompt window.
- Select Continue and sign in to Windows. Windows should boot in SAFE mode.
- While in Windows, press Windows key + r. Run msconfig command.
- Chose Boot tab and uncheck Safe boot. Reboot your system.
Hope this will help
Leon
RLuca1, I just wanted to check if the information posted previously was useful for you and if you need further assistance on this matter?
Alberto R.
A Contingent Worker at Intel
RLuca1, Since I have not heard back from you, we are closing the case, but if you have any additional questions, just reply back or post a new question.
Alberto R.
Topic Options
